Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > FT86CLUB Shared Forum > Regional Forums > NY / NJ / CT / PA
NY / NJ / CT / PA NY, NJ, CT, PA
Old 11-17-2017, 07:44 PM   #1
Breadman
Breadman's Avatar
Drives: 2017 BRZ w/PP
trusted emergency mechanic in pittsburgh
i really fucked up so here we go.
i was changing my oil like ive always done, take the cap off, take the plug out, take the filter off, oil a new filter ring, and was putting it on, first turn of my wrench my filter remover doodad broke and a piece smaller than my pinky went right in there. i saw it stuck to the side wall so i went to get some needle noise plyers. went to pull it out, tink tink tink all the way down. im going to assume im totally 100% fucked and need to tow it into the shop and have them tear it all apart for a tiny piece of chinesium. im not wrong thinking that putting oil in and hoping to flush it is batshit nuts?
here is my shitty diagram
Breadman is offline   Reply With Quote
Old 11-17-2017, 08:07 PM   #2
venturaII
Only users lose drugs.
venturaII's Avatar
Drives: All the time
Maybe it'd harmlessly work it's way to the oil pan and sit there. Or maybe it'd get pulled into the timing chain and sprocket, cause timing to jump, and you smash all the valves on that side of the motor. How good are you at gambling?
"To know a thing well, know it's limits. Only when pushed beyond its tolerances will true nature be seen." Amtal Rule
venturaII is offline   Reply With Quote
Old 11-17-2017, 08:15 PM   #3
Breadman
Breadman's Avatar
i mean i already lost the 1 and 1000 do i want to gamble again? also i sheered off where the wrech goes so the oil filter remover is stuck on the fucking filter
Old 11-17-2017, 11:31 PM   #4
BirdTRD
Simply Forgotus
BirdTRD's Avatar
Drives: 2014 Supercharged SSM BRZ Limited
That really sucks! I wouldn't drive it like that though.
Personally, before I took it to a shop, I'd maybe try to get eyeballs on it with an inspection scope and use some heavy duty magnets on the outside of the timing cover to try to walk it up to a place where you might be able to grab it with a telescoping magnetic retriever tool. $100 worth of Harbor Freight stuff and some time (and patience) might be worth the shot. Oh, and some beer for your buddy because this is probably going to be a 2 man job.
BirdTRD is offline   Reply With Quote
Old 11-17-2017, 11:51 PM   #5
Pgh_Area
Pgh_Area's Avatar
Drives: '14 Ultramarine Fr-S
Try Moore's Performance in McKees rocks.
Pgh_Area is offline   Reply With Quote
Old 11-17-2017, 11:55 PM   #6
ToySub1946
ToySub1946's Avatar
Drives: 15FRS, 05MustangGT, 85Toyota truck
You have not stated yet whether what was dropped is ferrous metal or not ? If it is, a small magnet properly placed may be your best friend...
What about just removing this (black plastic) sensor bottom left of front cover...see what access it gives you....before removing tin cover from lower camshaft.
ToySub1946 is offline   Reply With Quote
Old 11-18-2017, 08:05 AM   #7
Breadman
Breadman's Avatar
oh sorry everyone its non magnetic metal. straight chinesium
Old 11-18-2017, 09:26 AM   #8
Breadman
Breadman's Avatar
update: i called a shop that was recommended to me and they said they couldnt get it done in a reasonable time. they said if i had the old oil and it wasnt contaminated try and flush it out. i saw a rather large "glug" anomaly in the stream about 1/3 the way into draining it but couldnt find the piece in the stream. i then saw a lump when pouring it out in jug but the funnel didnt catch it. put new oil in started it, no crunch and idled just fine. im played a rather pricey dangerous game.
in the off chance i stop posting here, i didnt get it all and really really fucked my car and it was an honor posting here o7
Old 11-18-2017, 09:45 AM   #9
new2subaru
Weight Weenie
Drives: 15 FR-S
Why not run the oil through a piece of window screen to make sure?
Old 11-18-2017, 09:53 AM   #10
Breadman
Breadman's Avatar
because im a dumbass that never thought of that and got myself into in the first place being a dumbass. also i dont have a window screen
Old 11-18-2017, 10:32 AM   #11
Soloside
-Phil's BIGGEST FAN BOI
Drives: 2014 Greddy Turbo BRZ
or even a noodle strainer.
\0/
2014 Subaru BRZ
Don't follow your dreams, follow my instagram www.instagram.com/soloside
Soloside is offline   Reply With Quote
Any trusted websites for parts? xlMANNY Scion FR-S / Toyota 86 GT86 General Forum 2 06-12-2014 06:20 PM
Moto X trusted device / BRZ FA601US milhouse Electronics | Audio | NAV | Infotainment 1 02-27-2014 03:59 PM
Mr Wheels? Trusted shop? Danny Southeast 4 02-06-2014 04:25 AM
Trusted shop in GA for DI issue Bg8780 Issues | Warranty | Recalls / TSB 15 10-06-2013 11:42 PM
Anyone know a trusted shop? Partial Stall New England 13 08-06-2012 10:45 PM
