Drives: 2015 BRZ Series.Blue
225/45R17 Blizzaks
These fit ok on stock rims? I can get a good deal on them. Opinions appreciated.
Thanks! |
Drives: 2013 FR-S, Hot Lava; 2012 Z1000 CBO
Yeah, those will fit. That's the common size for autocross tires.
| The Following User Says Thank You to JohnJuan For This Useful Post: | rtalich (11-20-2017) |
Drives: 15 BRZ LTD, 05 FXT
They will fit.
With winter tires staying with a thin tire helps the tire cut down a bit. The car comes with 215's, but going square adds a bit of sidewall flex which should help retain grip. My preference in winter tires is to go with a slightly taller sidewall, with a square-fitting or OEM width tire, as this helps protect the wheel from bumps, curbs, ice dams, and pot holes, all common things in the winter. They should do pretty good, if you could get 225/55's that would be really nice on the stock wheels, and give you a teeny tiny bit of extra clearance. (I'm also really into 16" wheels for winters on these cars, so my advice may be missing the mark a bit!) Just about ANY winter tire that fits is infinitely better than the stock summers, and if it fits decent they'll be head and shoulders above even an all season.
SOLD: 2015 WRB BRZ Limited ('02 WRX BBS, S-04's, Stoptech Sport pads, MXP SP, AVO drop in filter, Mishimoto Intake tube, decatted header, OFT 93 Stage 2 EL Tune, Kartboy rear shifter bushing, Whiteline transmission and subframe lockout bushings, ST Coilovers, SPC Camber bolts w/smaller crash bolt, SPC LCA's & SPC Toe Arm bushings, Red TOMs, TRD Wing.)
| The Following User Says Thank You to JazzleSAURUS For This Useful Post: | rtalich (11-20-2017) |
| OEM Wheels, Blizzaks, potenzas, sensors | brz fred | Wheels and Tires | 1 | 05-03-2017 12:37 PM |
| Oem 17x7 wheels with blizzaks | HerrFunf | NY / NJ / CT / PA | 0 | 09-15-2016 10:14 PM |
| FS:Blizzaks WS 80 winter tires | UchihaFanBoy | NY / NJ / CT / PA | 10 | 07-31-2016 07:35 PM |
| WTS OEM RIMS WITH BLIZZAKS | Kazuya | Canada Classifieds | 0 | 04-30-2015 02:56 PM |
| FS: Blizzaks on Black Steelies | jvenetto | Wheels and Tires | 8 | 03-30-2015 02:38 AM |
