Old 11-10-2017, 04:12 AM   #1
rookietopro_frs
rookietopro_frs's Avatar
Drives: 2013 Scion FRS
Nardi Steering Wheel Help
My most recent modification was this Nardi Steering Wheel. Love how it makes my interior looks, but I'm still getting it dialed it. Me and friend finally got the horn issue resolved. Issue now is the ABS light & Air Bag light came on & having problems with my traction control. I've been doing some research, and what I read was that I need resistors? Bought it used, so I didn't know it was needed at the time. I don't want to purchase the wrong ones, anyone know where I can get them?
[ame="https://www.youtube.com/watch?v=RFy1B08IYR4&t=17s"]366 Mile Drive for a Steering Wheel ?! - YouTube[/ame]
rookietopro_frs is offline   Reply With Quote
Old 11-10-2017, 11:09 AM   #2
Mackizzle86
Mackizzle86's Avatar
Looks like you took the clockspring off. You just opened a can of problems.
You will need a Works Bell 540 or 542 hub and another Air Bag Light module.
Mackizzle86 is offline   Reply With Quote
Old 11-10-2017, 11:56 AM   #3
NyC Zn6
NyC Zn6's Avatar
Drives: 10 Series #974 6m/t
OP you will need these resistors https://frsport.com/Boss-Airbag-Resi...yABEgKlVPD_BwE . this will clear the airbag light. As Mac stated above you will need to adjust your clock spring which affects the traction and ABS. What hub are you using?
Old 11-11-2017, 01:14 AM   #4
rookietopro_frs
Thank you ! I'll purchase it ASAP. My clockspring still intact, but I didn't know how to properly adjust it. Tried put it at the 12 o'clock position, but my wheel is somewhat to the left still. Using the NRG Hub, not the short one.
Old 11-11-2017, 01:15 AM   #5
rookietopro_frs
No I still have it underneath the hub.
Old 11-11-2017, 11:13 PM   #6
Mackizzle86
OK, there are arrows in the 7 o clock area of the clockspring and you'll need to align those and there should be a recessed area behind the hub that goes in the clockspring before you put the steering wheel into the splines.
TBH, NRG hubs are the worst hubs on the market. You'll need a WB, Daikei or an HKB.
Old 11-11-2017, 11:17 PM   #7
e1_griego
e1_griego's Avatar
Drives: Many
NRG offers two hubs. The first one to market couldn't retain the clockspring.
The second one that they offer works fine.
The part number that works is SRK-125H.
e1_griego is offline   Reply With Quote
Old 11-13-2017, 04:08 AM   #8
rookietopro_frs
Wow I never notice the arrows in the 7 o'clock position, when I get my air bag resistors shipped in I'll definitely look for it.
Old 11-13-2017, 04:08 AM   #9
rookietopro_frs
I know I haven't had mine for a while, but I really like my hub & wheel setup.
Old 01-24-2018, 08:36 PM   #10
rookietopro_frs
Finally got mine dialed it !
Old 01-24-2018, 11:02 PM   #11
olsonpg
olsonpg's Avatar
Drives: BRZ. R34 GT-T
what was the dealio. I've never been able to properly adjust my Nardi with NRG hub.
I figured i might need an alignment or something to get my steering wheel 100% straight.
/ SARD / ENKEI / GREDDY / RACESENG / CUSCO / PERRIN / KW / POWERED BY MAX / SPARCO / STOPTECH / BREMBO / ROCKET BUNNY / FULL-RACE twin scroll / OS GIKEN / WHITELINE
olsonpg is offline   Reply With Quote
Old 01-31-2018, 09:53 PM   #12
rookietopro_frs
Apparently there is like an arrow that has to be in the 7 o'clock position on the hub. Had to redo it (carefully) several times. Good luck, cause I hated it not being aligned.
Old 01-31-2018, 11:45 PM   #13
olsonpg
olsonpg's Avatar
interesting, ill give that a shot!
Old 02-05-2018, 12:45 AM   #14
rookietopro_frs
Good luck & keep me posted.
Nardi Gara 3 Type 0 Steering Wheel $220 shipped JeremyR Interior Parts (Incl. Lighting) 0 08-11-2017 06:55 PM
Nardi Black Suede steering wheel Mikeran Interior Parts (Incl. Lighting) 1 01-19-2017 02:44 PM
FS: Nardi steering wheel, Team Voodoo shift knob, interior trim plus MORE! SLVRSRFR Canada Classifieds 21 02-14-2015 04:22 PM
FS: 330mm Nardi Sport Type A steering wheel bnib Bailey Interior Parts (Incl. Lighting) 1 12-06-2014 02:53 AM
Nardi Two Spoke Steering wheel Joakim3 Cosmetic Modification (Interior/Exterior/Lighting) 0 12-22-2013 03:59 PM
