Old 11-09-2017, 05:37 PM   #1
Dreamzqt
Drives: 2014 limited BRZ
OFT question!!!
Hello everyone I took my car to the shop and am getting my motor replaced.
I placed the stock tune back on the car and and its in the process of having the motor replaced with a used one.
I want to know if I can still use the same tablet to refresh my car to stage 2
Not sure if my stock tune on my oft will change with a new motor I'm a noob
Dreamzqt is offline   Reply With Quote
Old 11-09-2017, 06:47 PM   #2
Bookies
Drives: 2013 FRS
You might be able to get away with just flashing the stage 2 rom but if you re-flashed your stock tune before hand you should be able to plug the OFT up to your computer and there will be an "erase" option or something similar to reset it. Once you do that, it will be like plugging up a brand new OFT to your car and it should work fine.
Bookies is offline   Reply With Quote
Old 11-10-2017, 03:13 AM   #3
Kodename47
Kodename47's Avatar
Drives: UK GT86
The tune is in the ECU and nothing to do with the engine, unless they change the ECU, which they won't then the OFT won't know any different.
.: Stealth 86 :.
Kodename 47 DJ:
Old 11-10-2017, 03:20 PM   #4
Dreamzqt
thanks for the replies!
Turn Signal Relay Question (Dumb Question) Chimera Cosmetic Modification (Interior/Exterior/Lighting) 3 06-23-2017 01:58 AM
Question for the the 2014 Brz Nav Owners (BT Question) jbsali Electronics | Audio | NAV | Infotainment 3 07-16-2014 11:41 AM
HID Question mezdup Cosmetic Modification (Interior/Exterior/Lighting) 31 03-07-2013 11:19 PM
BEspoke question and rattle question bdanisi Electronics | Audio | NAV | Infotainment 2 01-30-2013 02:11 PM
a question about tax... pr086 Scion FR-S / Toyota 86 GT86 General Forum 34 06-07-2012 09:11 AM
