Old 11-09-2017, 11:54 AM   #1
palanza87
Drives: 06 Ford Mustang
Auto transmission jumping into manual mode on its own?
Hey everyone, not sure the best place to put this but has anyone had a problem where their auto transmission randomly starts shifting form auto to a manual gear? Like it'll go from D to 3 on the dash. It went from d to 4 and even started randomly shifting down to 2nd when I was definitely going too fast for 2nd.
Any suggestions where to begin troubleshooting?
2013 frs
palanza87 is offline   Reply With Quote
Old 11-09-2017, 12:23 PM   #2
FoxHound101
FoxHound101's Avatar
Drives: 2015 FR-S
2013 frs
Hey there! Quick question, while driving in auto did you touch your paddle shifter? Because if you did even though you are driving in auto that will cause the car to up shift or down shift and it will switch to D to the gear its currently in. Thats normal.
FoxHound101 is offline   Reply With Quote
The Following User Says Thank You to FoxHound101 For This Useful Post:
Tcoat (11-09-2017)
Old 11-09-2017, 01:36 PM   #3
palanza87
Unfortunately no, i wish it was that simple. I'll keep an eye on it though to see if maybe bumps are triggering it.
Old 11-09-2017, 01:42 PM   #4
Changed anything in the steering? Removed the consul or done any work on or around the shifter?
Old 11-09-2017, 01:43 PM   #5
HKz
Reformed
HKz's Avatar
Drives: '23 GRC, '11 Prius, '04 RAV4
2013 frs
if you're in sport mode it will down shift heavily on its own especially when you are hard braking but it certainly doesn't go into manual mode..
post up a vid
HKz is offline   Reply With Quote
The Following User Says Thank You to HKz For This Useful Post:
VoltsFRS2013 (11-09-2017)
Old 11-09-2017, 10:06 PM   #6
palanza87
Well I bought the car used but the seller never mentioned anything like that.
post up a vid
Unfortunately the issue seems random for now, I can't reproduce it on purpose yet.
Just imagine u are going 55 mph in full auto mode. Prob 6th gear but it just says D on the dash.
Then out of nowhere the D turns to 4 and the revs shoot up. Then as I let off the gas the 4 turns to 3. Meanwhile nothing has been physically adjusted. I then pull the shifter to manual and back to auto and it resets back to normal.
Old 11-10-2017, 09:25 AM   #7
The previous owner may have had the console and shifter apart for some reason and you simply have a loose wire. Would make sense why going from manual back to auto works for a while. Any random bump could cause it to move and change again.
Auto vs Manual Transmission ThornhillSubaruOwner Engine, Exhaust, Transmission 44 10-02-2016 11:51 PM
Auto Shifting in Manual Mode phantasticity Engine, Exhaust, Transmission 22 06-16-2016 09:56 PM
Auto Transmission Driver: what driving mode ? djmm Scion FR-S / Toyota 86 GT86 General Forum 9 07-09-2014 12:42 PM
Keep Auto Transmission or Switch to Manual Stayreal Engine, Exhaust, Transmission 41 03-23-2014 10:02 AM
is it possible to rejigger the auto manual mode shifter to flip gear up/down? chickdigger802 BRZ First-Gen (2012+) — General Topics 14 10-18-2013 08:17 PM
