Old 11-06-2017, 03:18 PM   #1
Toxicmilk45
Toxicmilk45's Avatar
Drives: White out FRS
Taking apart blown fa20
I am doing this disassembly because the engine blew and I have no plans to rebuild it.
I already have the car running on a 3SGE and I am planning on turning the FA20 into a table.
This is not how I would take apart an engine that I would try to rebuild.
[ame="https://www.youtube.com/watch?v=LZDS0w16aVM"]https://www.youtube.com/watch?v=LZDS0w16aVM[/ame]
Instagram: schen_86
3SGE FRS Build Thread: http://www.ft86club.com/forums/showthread.php?t=114039
Toxicmilk45 is offline   Reply With Quote
Old 11-06-2017, 03:39 PM   #2
nextcar
Guilt free parts vulture!
Drives: 2024 GR86 Trueno Halo 6MT
Speechless.
Originally Posted by drewbot
Pull out
nextcar is offline   Reply With Quote
Old 11-06-2017, 06:33 PM   #3
Capt Spaulding
Persona Non Grata
Capt Spaulding's Avatar
Drives: '15 BRZ (WRB)
Originally Posted by nextcar View Post
Speechless.
I'm not exactly sure how you mean this. One thing I can say with complete certainty, these are NOT the guys I want working on my car.
Slow is smooth, and smooth is fast
Capt Spaulding is offline   Reply With Quote
Old 11-06-2017, 06:56 PM   #4
stevesnj
stevesnj's Avatar
Were you taking it apart for fun or rebuild purpose?
My 2016 Build thread
Old 11-06-2017, 08:51 PM   #5
bcj
Geo Tyrebighter Esq
bcj's Avatar
Drives: '13 scion fr-s
Thanks. I think...
Steel pry bars on aluminum sealing surfaces no bueno.
Not in the market for a shortblock right now.
Entertainment purposes only
Old 11-06-2017, 09:03 PM   #6
new2subaru
Weight Weenie
Drives: 15 FR-S
Old 11-06-2017, 09:47 PM   #7
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
Looks like all the money came out with the oil pan.
Old 11-06-2017, 09:47 PM   #8
whataboutbob
AutoX-10/10ths every run
Looks like money shift carnage.
Build thread:Here
Old 11-06-2017, 09:48 PM   #9
Thanks. I think...
Originally Posted by new2subaru View Post
4:50
I knew the engine was already toast but still physically cringed every time that mallet hit that screwdriver.
If it was for rebuild it is just for fun now.
Old 11-06-2017, 10:36 PM   #10
Grady
Grady's Avatar
I think his helper has has a little bit too much to smoke. Engine defiantly totaled after that disassembly.
His shirt may have somthing to do with why to blew in the first place?
Old 11-06-2017, 11:18 PM   #11
nextcar
I think you nailed it.
Assistant appears higher than a kite or dumber than a rock...
"breaker bar"/pipe over swivel headed ratchet...
Bending the tube being used as a pry bar...
Screw driver/mallet seal breaker on machined surface...
Surprise over the cleanliness of a modern engine with under 30K miles...
Design comments on the engineering of the engine by two dudes not qualified to build lawn mower engines...
Impact wrench on the crank pulley bolt followed by "I think its stripped"
I could go on, but why? My 2 cents is that this was a failed pitch for an "Ernest goes to mechanic school" film.
Pull out
Old 11-10-2017, 09:37 PM   #12
Toxicmilk45
This engine has a hole in the block and I have no plans on rebuilding it. I am only taking this apart to make into a table chill out guys.
Instagram: schen_86
Old 11-10-2017, 10:01 PM   #13
That is what I figured but watching the mallet fall still chilled me to the bone.
Make a cool table.
Free blown stripped FA20 C130NAV NY / NJ / CT / PA 4 07-19-2016 05:56 PM
For Sale; blown FA20 or parts PolishFrs13 Engine, Exhaust, Bolt-Ons 4 12-29-2015 05:33 PM
F/S FA20 Blown Rod C130NAV NY / NJ / CT / PA 2 02-23-2015 08:48 AM
WTB: FA20 Long Block/Short Block blown/running The Racers Line Engine, Exhaust, Bolt-Ons 7 07-29-2014 01:26 AM
FINAL RESULTS: Taking Full Blown Stage 1 To The MAX! @Pure Automotive (Dyno Inside!) Pure Automotive Forced Induction 57 03-27-2013 11:41 PM
