Old 11-05-2017, 10:52 PM   #1
Heidorf
Drives: 2015 Scion FRS
255 on stock suspension
Just bought a set of Work D9R 18x9.5 +38. Looked everywhere online to see if 255 tires would fit on stock suspension. I read that they fit with no rubbing issues and also read that you couldnt run them out all w/o coils. Does anyone know for sure if i could run this setup without coils?
Heidorf is offline   Reply With Quote
Old 11-06-2017, 04:54 AM   #2
tyler_win_photo
tyler_win_photo's Avatar
There's a sticky for this. I'm going to say the clearance with the strut is going to be very close.
Keep in mind different tire manufactures have different tire widths for a certain size. For example Federals most people say run a size larger than what they are labeled
tyler_win_photo is offline   Reply With Quote
Old 11-06-2017, 06:36 AM   #3
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Next time check twice before buying. It'll save you time and money.
Old 11-06-2017, 08:25 AM   #4
dattran86
Driver
Drives: 2013 Whiteout FRS
my current set up 255/40 with a 17x9 +45 on stock suspension
DSC_4167 by Apex 86, on Flickr
DSC_4164 by Apex 86, on Flickr
Check out my website:
http://www.aim4apex.com/
IG: aimforapex
dattran86 is offline   Reply With Quote
Old 11-06-2017, 10:53 AM   #5
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
He has a bit widder wheel than yours and I am not sure about your offset. In any case, it is wrong to buy something and question afterwards if it fits in the car.
Old 11-08-2017, 11:35 PM   #6
BAD ROD
Drives: 2014 BRZ
Great question. I don't know for sure, and would like to find out as well. I would like to run 255's on lowering springs/stock struts (or even on stock).
Right now I'm running Work Wheels T7R 18x9.5 +38, 245/35/18, totally stock and no rubbing what-so-ever. I have been meaning to measure if I can go to a 255.
The posts are not consistent on whether 255 will fit. Heck you can find many posts that say 18x9.5 +38 wheels won't fit on stock suspension and I have been running that for 10's thousands of miles.
BAD ROD is offline   Reply With Quote
Old 11-08-2017, 11:38 PM   #7
BAD ROD
Drives: 2014 BRZ
The way I read his post is that he bought the wheels, which we know fit, and he is wondering about 255 tires, which he has not bought. Nothing wrong there.
If his wheels had tires, he could just bolt them on and see if they fit.
Old 11-09-2017, 02:41 AM   #8
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
The topic says 255 on stock suspension. It doesn't say 255 on 9.5 wide wheels. You don't have clearing issues, but depending of how you drive you might have rubbing issues. The problem is the spring rates which can handle well up to 225-235 tires.
By the way, why are you guys going so wide? Is it for the looks or for performance? Going much wider and larger is not always optimal on a stock car and engine. There isn't much power on these cars. Check how much smaller is the max track speed below. The lap time is also worse:
http://www.roadandtrack.com/car-cult...ransformation/
Old 11-09-2017, 11:22 AM   #9
BAD ROD
Drives: 2014 BRZ
Not a big deal, I was just pointing out that regarding the topic saying 255 was that he WAS asking the question of fitment before purchasing the tire. I'm sure you get it.
I don't have rubbing issues under any and all types of driving (245's, I have not tried 255's yet).
For me, I would want a 255 tire for looks. If I wanted performance, I would not be driving a BRZ.
2017 Stock Suspension VS RCE Yellows on Stock 13 FRS TeutonicShift89 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 37 04-06-2018 08:39 PM
FS Stock Suspension and stock exhaust Illinois Full_Throttle_86 Great Lakes 2 09-24-2015 10:44 AM
WTB: Stock OEM FR-S Suspension stevohl Want-To-Buy Requests 16 05-05-2015 07:36 PM
WTB stock rear tophats or complete stock suspension s13kid989 Want-To-Buy Requests 3 10-09-2014 07:11 AM
Mix & Match stock FR-S and stock BRZ suspension and/or springs Weasel Soup Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 09-08-2014 01:53 PM
