Drives: 2017 Subaru BRZ Premium
Catback exhaust pipes STUCK?
I recently installed the MXP Comp rs catback exhaust system on my 17' BRZ. It sounds great, but I came across a couple problems during the installation.
The pipes which are meant to slide over each other, were slightly morphed and don't fit properly. The y-pipe on the end had a hard time going over the 2nd pipe. It went only half way over the 2nd pipe, leaving a gap in between the slits that can possibly cause an exhaust leak. Now the pipe is stuck in that position. I tried to force it in to seal the gap, but it is completely stuck. Then I tried removing it, no luck. What can I do to get the pipe to slide all the way in? |
Butane torch?
| The Following User Says Thank You to funwheeldrive For This Useful Post: | DAEMANO (11-06-2017) |
Time Traveller
Yep, this is the move.
@pjaaaay heat up the larger pipe with a butane torch. The metal will expand. You should then be able to slide it off. Careful to not accidentally heat up the smaller pipe and expand that one too. Also careful to not light the car or yourself on fire. gl/hf |
| The Following User Says Thank You to DAEMANO For This Useful Post: | Cole (11-08-2017) |
Once you get it off using the heat and while it is still hot use a U-bolt to round it out better. Just tighten the bolt against the high points on the pipe until you push it back into place. Don't get carried away and make the high spots the new low spots though.
I am struggling to write how to do it. Does this make any sense at all?
Try bringing your exhaust to an exhaust shop and having them cone the bent exhaust piece(s). Worst comes to worst just have it welded together. Slip on exhausts are prone to leaking even if they may look like they have a good seal.
AVO Stage 2 Turbo Build Thread
https://wheelwell.com/tyler-nguyen-1...014-scion-fr-s |
| The Following User Says Thank You to tyler_win_photo For This Useful Post: | Tcoat (11-08-2017) |
This is the very best solution!
Drives: 2022' GR86 Premium 6MT
Exhaust shop or a butane torch and a dremel tool. Thats what I used to install my Muffler delete onto a very stubborn and rusted OEM downpipe last summer.
PS. dont tell my dealership that
22' Toyota GR86 - Trueno Blue - M/T (CURRENT)
18' Toyota 86 GT Black - Moonslate Gray - M/T (SOLD) 13' Scion FRS - Ultramarine - A/T (SOLD) |
| Tags |
| exhaust |
| Exhaust Tips for 2013/2014 Stock Exhaust Pipes | RickyBobby | Engine, Exhaust, Transmission | 9 | 02-06-2023 12:29 PM |
| ΘΘΘ Tomei Titanium Exhaust Systems ΘΘΘ Cat Backs, Front Pipes, Over Pipes and Headers | FT-86 SpeedFactory | Engine, Exhaust, Bolt-Ons | 291 | 02-16-2017 11:37 PM |
| JDM TRD Catback with Invidia front pipes | Ray_32 | Engine, Exhaust, Transmission | 4 | 04-23-2014 05:10 PM |
| CATBACK, DOWN & MID PIPES, HEADER - Proven exhaust systems on sale at 86Insider.com | 86_Insider | Engine, Exhaust, Bolt-Ons | 1 | 09-03-2013 06:51 PM |
| Invidia N1 Exhaust + Front Pipes and MXP Catback | FBPARTS | Engine, Exhaust, Bolt-Ons | 0 | 01-10-2013 11:23 AM |
