Old 11-03-2017, 06:10 PM   #1
Skeneypoo
Skeneypoo's Avatar
LS Accessory Drive Spacing
Hey hey. I'm getting parts ready for my LSX swap pretty soon and am wondering how much room there is between the radiator fans and the LS accessory drive?
It would be useful to know if the stock accessories could be used when using a truck motor (lq4) vs having to swap them with the F-body or Corvette accessories.
According to holly, there's only a 3/4" different between the truck and f-body (typical camaro ls1), accessory drive.
I plan on picking up which ever motor I can get first/cheapest but would like to know if there's an extra 1.5" of space between the fans and motor.
Thanks
Covette - F-Body - Truck
Skeneypoo is offline   Reply With Quote
Old 11-03-2017, 09:14 PM   #2
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
It’s possible you could swing it with slim fan setup, and maybe spacing the radiator a little bit forward.
@DustinS would be able to tell you more I think.
Old 11-03-2017, 10:45 PM   #3
Skeneypoo
Skeneypoo's Avatar
That. Would. Be. Awesome. Scooting it forward *shouldn't* be difficult, maybe when @DustinS chimes in he can tell me if there's clearance issues with the front cross member. Even that wouldn't be hard to notch and strengthen with a few angles. A little fab work never hurt anyone.
Old 11-04-2017, 09:09 AM   #4
all4spl
from what I have gathered. The CX racing kit uses F body accessories and it is very close. You even have to trim the hood latch assembly which is less than ideal. Truck accessories let alone the water pump, I would think wouldn't work very well. Switch to CTSV or corvette accessories if you can.
all4spl is offline   Reply With Quote
Old 11-04-2017, 11:49 AM   #5
Merc
Drives: Subaru brz 2013 LS1 swap
Do you have to run an aftermarket radiator or has anyone used the stock?
Merc is offline   Reply With Quote
Old 11-04-2017, 12:08 PM   #6
Skeneypoo
Skeneypoo's Avatar
Ok cool. I'm all for cars being a never ending project so I think the "sensible" way to go is to find an C5 (1997-2004) LS/T56 package from the get go, slap a gto shifter on it and call it a day.
Probably way easier to find one out of an F-Body though, so when I start having cooling issues, which is likely be immediately, I'll try to push the radiator forward a bit and slap on some junkyard C5 accessories in her.
Awesome info, thanks!
Old 11-04-2017, 12:50 PM   #7
ILLSMOQ
Drives: 2017 WR BLUE BRZ
You don’t want a c5 t56
ILLSMOQ is offline   Reply With Quote
Old 11-04-2017, 01:42 PM   #8
Skeneypoo
Skeneypoo's Avatar
Damnit you're right. Different mainshaft to fit it to any of the other LSX's among another things. Good looking out
Old 11-05-2017, 08:12 AM   #9
Sportsguy83
Drives: Limited BRZ
I'd say aftermarket. The stock radiator is tiny and I know for a fact (a local tried it) it's not enough for a 2JZ.
Old 11-05-2017, 02:57 PM   #10
Merc
That's pretty much what I figured, any suggestions heard mixed reviews on the mishimoto
Old 11-06-2017, 12:45 AM   #11
Skeneypoo
Skeneypoo's Avatar
Popular radiator but having good fans and a shroud thats mounted so it doesn't let air escape is likely more valuable than the brand name itself. Get a good 3 row and you should be good.
Old 11-06-2017, 10:29 AM   #12
DustinS
DustinS's Avatar
Drives: 2013 Ultramarine FR-S
I recommend the Full Blown Radiator. I don't have any issues with mine.
I am using CTS-V accessories and it is pretty close. I'll try and get some photos later today. I removed the hood latch to make room for intake/venting. So I don't have the center support beam.
DustinS is offline   Reply With Quote
Old 11-06-2017, 01:41 PM   #13
DustinS
DustinS's Avatar
Few I found in my picture stash
Old 11-06-2017, 03:30 PM   #14
Skeneypoo
Skeneypoo's Avatar
Really appreciate the photos man! So awesome. Kind of hard to tell from the angle on the last pic, but does the crank pulley sit above the front crossmember? On the first picture, it looks like it absolutely does not, and the second looks like it absolutely does haha.
Were to get LS4 accessory drive kit Zer0 Engine Swaps 17 08-07-2017 08:39 PM
Will they fit? 15x7 0 offset (4 inch back spacing) alanhung85 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 03-05-2015 12:28 PM
What are the biggest wheels and spacing before requiring any other special modificati WallsAndFoundations Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 12 07-05-2014 08:16 PM
What do these accessory codes mean? FastLap Scion FR-S / Toyota 86 GT86 General Forum 3 08-06-2012 05:56 PM
STi's newest accessory!!! Godzpeed Off-Topic Lounge [WARNING: NO POLITICS] 7 07-08-2012 01:21 AM
