Drives: 15' Limited BRZ
Cracked fuse box housing
Hi I have a 2015 limited Subaru BRZ, the fuse box was cracked when I bought the car and all it has is the cover with no lower portion to mount onto the chassis so it just sits there collecting heat. I see I can purchase a 2013 Scion FR-S automatic fuse box I don’t need the actual fuses or the box just the plastic housing the shape and dimensions of the box is the same right?
Drives: SWP BRZ
if you just need box, then it should be same. manual/automatic has same location of fuse box
Hey thanks for the reply my big question is does it have the same shape and dimensions and size as a BRZ (Subaru) 2015 (one I’m buying is 2013) manual (one I’m buying is automatic) fuse box and does it have the same kind of fuses in the same places
Did a quick look and couldn't find a part number but from the drawings they are all exactly the same. Make, year and model shouldn't matter. The fuses and relays can vary slightly but you can just make sure you match what you have when you put them in. All the spaces are there.
| PTE 6466, 1.0 divided A/R, polished comp housing, black ceramic turbine housing | slicktop | Engine, Exhaust, Bolt-Ons | 6 | 10-17-2015 10:53 PM |
| Cracked Housing? | OURO3OROS | Cosmetic Modification (Interior/Exterior/Lighting) | 7 | 02-02-2014 07:43 AM |
| Cracked Oil Pan?! | Jolaessss | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 12 | 11-21-2013 02:28 PM |
| Has anyone cracked the OEM rotor yet? | ayau | Tracking / Autocross / HPDE / Drifting | 10 | 04-22-2013 04:41 PM |
| Cracked Rim | SmsAlSuwaidi | Issues | Warranty | Recalls / TSB | 29 | 04-02-2013 01:30 PM |
