Old 10-30-2017, 03:54 PM   #1
Casey10s
Casey10s's Avatar
Drives: 2013 white limited BRZ
Need Input for Solving Issues
On the last couple of track days, I have had some issues and would like to get some input on possible causes/solutions.
I changed my rotors and pads before my last track day. Everything seemed normal until the end of the second session. Under medium to heavy braking, I started to hear some noises that sounding like something wasn't smooth (not necessarily grinding but maybe something was dragging) but no real vibration. The few times I have had the car out on the streets since then, I noticed it was probably coming from the front driver's side. Any ideas? I was thinking either wheel bearing (which should be noisy all the time), caliper going bad, or maybe something else. Any suggestions? I also took the pads out and checked them out also looked at the wheel and rotors. All wheels/rotors look OK.
Also I started to use an OBD reader. I was getting funny lights coming on the dashboard as I started to connect my phone to the OBD unit. Things like lost communication with different control units was the code reason. This happened like 3 times over 2 track days. Can the OBD reader cause that? Anything to worry about? It seems to go away if I turn the car off and leave it sit for a minute or so. Anything to do to lessen this from occurring?
Casey10s is offline   Reply With Quote
Solving the transmission problem. The R154. krimsonmedic Engine, Exhaust, Transmission 23 09-12-2017 10:54 PM
Need some sensible input... to FI or not modbus Forced Induction 63 09-02-2016 10:15 PM
Need some input LOOK!! skavengers412 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 02-21-2016 12:50 PM
Looking for SUV Input ap5512 Other Vehicles & General Automotive Discussions 16 09-23-2014 02:48 PM
Asking for some input on accents JoeBoxer Cosmetic Modification (Interior/Exterior/Lighting) 16 12-18-2012 05:22 PM
