Drives: 2015 FR-S
Type of base for H11 bulb?
I went to order a set of H11 HID's for my 2015 FR-S. The options had 4 options for the base of the bulb:
H11 H11B H11 L shaped base H11 metal Base Here is what I am trying to order: https://www.amazon.com/gp/product/B0...e?ie=UTF8&th=1 I did try searching for combinations of "HID H11 base" but none of the subjects even had anything to do with headlights. Anyone got an idea of which I should be getting? Dan |
Drives: 2015 Scion FR-S
I believe b is the type of connector L is the way the base is. And obviously metal base is metal. With that said, I believe it's H11 normal. The metal base uses a wire spring loaded system to keep it in. My old mr2 had those.
I'll double check the bulb in a few minutes. I also have some hardly used diode dynamic hid ballasts if you're interested. |
| Dealer set the wrong Car Type in FR-S base audio | pkny | Electronics | Audio | NAV | Infotainment | 112 | 05-08-2017 10:04 AM |
| WTB: Voltex Type 7 Swan Neck Wing with FRS Base Plates | leunglambs | Want-To-Buy Requests | 1 | 01-09-2017 01:44 PM |
| SPECIAL PRICE TOMEI TITANIUM MUFFLER TYPE -80,60S,60R/FRONT STRAIGHT PIPE TYPE-80,60 | myjdmparts | Groupbuys | 15 | 10-08-2015 10:41 PM |
| HID bulb size/type on Monogram series | chicagokid | Cosmetic Modification (Interior/Exterior/Lighting) | 1 | 05-27-2014 12:20 AM |
