Drives: 2014 Asphalt FRS
Stage 2 question
I apologize in advance for such a common question, but after an hour of research I am not crystal clear yet.
I have a UEL Header on my frs, and i want to get a kit for e85, and of course a tune for both. What do I need to purchase? Ecutek? Open flash kit and tablet? Delicious tuning kit? Also, I am slightly paranoid.. is there ANY danger in running e85 on a car that is technically not designed for it? I know the kinks in it such as sometimes you can't start in the cold. I'm interested in e85 because I would like to get the most out of my NA motor. Thank you for your time. |
#2 | |
Drives: 2017 BRZ Limited
1) Get an open flash tablet (OFT) and do the e85 tune on there. The thing with OFT is that you have to retune again if you want to start using regular gas again. You CAN NOT mix e85 and regular gas when on a OFT e85 tune. 2) You can get an actual flex fuel kit that will sense your ethanol content, like the delicious tuning kit you mentioned. You CAN mix e85 and regular gas while running a flex fuel kit and there is no need to retune your ecu if you want to use one or the other. This path, however, will cost much more since you have to buy the flex fuel kit AND the ecutek tune in most cases. Imo, getting the flex fuel kit would be the best option. I would het annoyed of retuning my ecu. One of my friends has been running e85 for months without any issues at all. Only downsides I can think of is more trips to the pump and sometimes your engine won't start on the first turnover. Edit: here's another thread of info if you haven't read it already. http://www.ft86club.com/forums/showthread.php?t=53477 Last edited by Harjotdhanota; 10-17-2017 at 04:19 AM. Reason: Added info |
Noob
Drives: FR-S Mammogram
What Harjotdhanota said is pretty spot on.
As someone who's done both, I recommend option 2. However, you can try out option 1, as OFT are resellable. An EcuTek license is not resellable (since it is unique to your ECU).
Drives: Toyota GT86
OFT has also Flex-fuel
![]() Created by ztan for MT and ported to AT by Wayno
"Oversteer is when your ass hits the wall, Understeer is when your face hits the wall!" - Unknown Stockcar driver
BeNeLux FB group: GT86/BRZ Owners |
| Question about Catted Headers + OFT Stage 1 Tune | djenousis | Software Tuning | 0 | 05-25-2017 11:38 PM |
| JDL UEL HFC Headers OFT 93 Stage 2/1 Tune Question | neilvosko | Software Tuning | 2 | 03-05-2017 09:38 AM |
| Question for anyone with OFT Stage 2 UEL tune on the track, did it make a difference | Str8Ghostin | Tracking / Autocross / HPDE / Drifting | 8 | 06-30-2016 03:53 PM |
| Question; What Strut-tower bars and cross-braces fit with Innovate Stage 2 I/C SC? | Michael Blue | Forced Induction | 5 | 05-26-2014 01:30 AM |
| ECUTEK STAGE 2 Question. HELP! | Fresh86 | Software Tuning | 2 | 11-07-2013 10:34 AM |
