Old 10-03-2017, 03:58 PM   #1
Scion_Swine
Drives: 2017 Subaru BRZ
leased BRZ on the track
I leased a BRZ with performance package.
I used to have a stock FRS that I have upgraded all fluids, tires, and brakes before the track.
Now I have a new BRZ with performance package and a little under 1000k miles. I will be tracking in about a week or so, for the first time with this car. Should I do the same upgrades I did with the FRS or can I just leave it the way it is and just change everything as per service manual since I have a service package with the dealership?
and I am thinking that since it has a "performance" package id assume Subaru would make it track ready out of the box.
"Practice makes better. Only Senna is perfect." - CSG Mike
Scion_Swine is offline   Reply With Quote
Old 10-03-2017, 04:03 PM   #2
mkivsoopra
"performance package" does not mean track ready, so you'll want to do the same stuff as you've done before, plus any maintenance items for being at 1,000,000 miles .
mkivsoopra is offline   Reply With Quote
Old 10-03-2017, 04:08 PM   #3
8RZ
The Gunshine State
8RZ's Avatar
Drives: '14 BRZ Limited
inb4 warranty denied!
Current DD: M235i
8RZ is offline   Reply With Quote
Old 10-03-2017, 04:10 PM   #4
Scion_Swine
Would I still be able to survive a track day with the stock components, since they are fairly new, and replace them after the day?
my concern is if the brake pads are street compound would they survive and be able to get me home and daily drive until new compound comes in?
Old 10-03-2017, 04:18 PM   #5
Code Monkey
Drives: Subaru BRZ
Just do it, what can go wrong.
Code Monkey is offline   Reply With Quote
Old 10-03-2017, 04:23 PM   #6
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
Wow, 1,000,000 miles. Boy is that going to cost you at the end of your lease.
Old 10-03-2017, 04:26 PM   #7
ryan t
Drives: frs
i hope you buy track day insurance too
ryan t is offline   Reply With Quote
Old 10-03-2017, 04:33 PM   #8
strat61caster
strat61caster's Avatar
How much did you use up the pads on your last car?
If you were killing street/hybrid pads and using up track pads at a decent rate then I'd suspect you'd kill the stock PP system as well by the end of the day. If you were ok on street pads like Hawk HP or Stoptech on track then I think you may get away with tracking the PP mostly stock. Hybrid pads would be a toss up.
I'd do brake fluid at an absolute minimum. Really the braking system is the weakest point on an 86 for track duty so it comes down to what pads you think you'll need to have a fun safe day.
ineedyourdiddly
Old 10-03-2017, 04:46 PM   #9
FirstWinter
Drives: Car
Get brake pads & brake fluid.
FirstWinter is offline   Reply With Quote
Old 10-05-2017, 06:55 AM   #10
doctor_driver
Drives: 17' BRZ - PP
Don't worry about pads and fluids on your first day out in it. I did 3 hours in one day on a track in mine back in March with 100% stock components and it handled it like a champ. Had to swap fluid and pads after, but I didn't notice any pedal softness or anything until I was in my 2nd to last session.
doctor_driver is offline   Reply With Quote
Old 10-05-2017, 12:29 PM   #11
Scion_Swine
I'm thinking of doing that just so I can experience some brake fade so I can learn to react properly in that situation without being completely out of skill. I figured that these cars are designed to be teetering on the limit, to help train the nut behind the wheel, so I'd assume the brakes would be on a similar standing.
But at the same time I'd rather enjoy the whole track day with brakes that always work.
But this might be a dumb question. Since the performance package has bigger brake calipers and disks, are the pads bigger as well?
Or do I just get the same stoptech pads I did before?
Link:
http://www.ft86speedfactory.com/stop...l#.WdZapeApA0M
Old 10-05-2017, 12:34 PM   #12
strat61caster
Link:
If you were fine on those stoptech pads you'll be fine on the PP, you'd probably be fine on stock pads as well.
imho do a fluid flush anyway.
You don't have to be paranoid about your brakes all day, but pay attention to how they feel along with the million other things you should pay attention to.
If they start feeling soft then ease up, get off throttle a bit early when you come up to the corner and ease onto the brakes, ease off of them, don't hit them as hard and you'll be fine. You can still have fun carrying momentum and powering out of the corner.
ineedyourdiddly
Old 10-05-2017, 12:37 PM   #13
DAEMANO
Time Traveller
Pads and fluid, yes.
Remove license plates. Do it.
Old 10-05-2017, 01:18 PM   #14
redlined600
redlined600's Avatar
Drives: Fr-s
Why risk it over something so trivial. Fluid at a minimum.
Noob with a leased FRS..what can I mod? MrAnthonyC Scion FR-S / Toyota 86 GT86 General Forum 49 03-18-2017 01:11 PM
Just leased a 2015 F-RS tony707c Scion FR-S / Toyota 86 GT86 General Forum 22 12-30-2014 10:26 PM
If You Leased... tdoggy57 Scion FR-S / Toyota 86 GT86 General Forum 23 07-14-2013 08:37 PM
Leased car question Minovsky Cosmetic Modification (Interior/Exterior/Lighting) 11 05-04-2013 02:03 PM
Those who leased their FRS / BRZ I have a question.. HapaHaole Southern California 5 08-07-2012 11:04 AM
