Old 09-28-2017, 11:52 AM   #1
louisfrombaltimore
Drives: 2017 BRZ PP
2017 Limited Oil Temp?
Hey ya'll,
Does anyone know how accurate the newer oil temp gauge on the 2017 models is? Curious if I should trust it or if it's just a dummy gauge.
Cheers
louisfrombaltimore is offline   Reply With Quote
Old 09-28-2017, 12:10 PM   #2
tacos
Drives: 09 impreza, 01 crv, 17 brz PP
just a guess here... but i really doubt its a "dummy gauge"
seems pretty accurate to me
while having the gauge displayed, you can hit the middle button on the D-pad on the right side of the steering wheel to show/hide temp numbers
tacos is offline   Reply With Quote
The Following User Says Thank You to tacos For This Useful Post:
nico_rsx (09-28-2017)
Old 09-28-2017, 12:32 PM   #3
Code Monkey
Drives: Subaru BRZ
No idea how accurate it is, but I often see around 240-260 when I drive around town and keep the revs in the upper range.
Code Monkey is offline   Reply With Quote
The Following User Says Thank You to Code Monkey For This Useful Post:
Clipdat (09-28-2017)
Old 09-28-2017, 12:57 PM   #4
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
depending on how spiritedly you're driving...that is probably pretty accurate
The Following User Says Thank You to continuecrushing For This Useful Post:
Old 09-28-2017, 03:52 PM   #5
TofuJoe
Ohne Titel
TofuJoe's Avatar
Drives: 2017 BRZ PP ISM
I compared the 2017 dashboard gauge to the DashCommand app hooked up to a bluetooth dongle. The info must be coming from the same place, because the numbers are exactly the same.
The dashboard gauge is really nice to have - easy to read that 190 degree point, and good not to push the car until the oil warms up.
That being said, it's difficult to tell just exactly what the temp is on that scale once you get above 190 degrees. I was finding that it was easy to hit 230-240 degrees just driving around the canyons. This was the same in the 2013 that I previously had.
Had my mechanic install the Perrin oil cooler, and now I'm more in the 210-215º range when driving in the canyons. Should be perfect for keeping oil temps reasonable once i start hitting the track again, too.
TofuJoe is offline   Reply With Quote
Old 09-28-2017, 04:38 PM   #6
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
It's 100% accurate for what you want to know: general engine oil temps.
If you have a specific need for oil temps to hit a target mark, you would run secondary/independent sensors to get the readings you want anyhow.
-alex
Old 09-29-2017, 07:52 AM   #7
louisfrombaltimore
Drives: 2017 BRZ PP
Cool, thanks for the responses everyone
2016 BRZ Limited VS 2017 Jeep Grand Cherokee Limited BDKane01 FR-S / BRZ vs.... 19 02-24-2017 01:08 AM
2017 Subaru WRX STI, STI Limited, WRX, WRX Limited, WRX Premium mark0006 Other Vehicles & General Automotive Discussions 0 10-27-2016 06:22 PM
FS: BNIB Prosport Guages (Water Temp / Exhaust Gas Temp) AtlasMick Interior Parts (Incl. Lighting) 2 03-31-2015 05:47 PM
STRI DSD SLM II Gauges (boost/oil temp/oil press/water temp/egt) BNIB ziptiedae86 Interior Parts (Incl. Lighting) 0 10-29-2013 11:50 PM
