Old 09-26-2017, 10:28 PM   #1
Plaid Man
Drives: 2013 Scion FR-S - Raven
FS: MCS double adjustable shocks
FS: Full set of MCS 2WNR (double adjustable) shocks for the Twins. This is the
best picture I have of these at the moment since they are on the car.
I am moving from SCCA DS to SSC for next year and no longer can use these shocks (SSC has a spec Koni Shock).
These have been great shocks for me and have given me a great opportunity to tune a wide range of compression and rebound damping and learn what each do to the car.
They have a billet machined spring seat that is adjustable and accepts stock type springs. The spring seats can be changed to accept race springs and be used in STX.
These shocks are in great condition with no leaks or damage. They are fully rebuildable by MCS in the Atlanta area if the need arises.
These will be available November-ish as I will finish out this season on these shocks and make the switch over the winter.
The shocks are about 3 years old and have less than 10k street miles on them.
Asking $2000 for the set. Buyer pays actual shipping fees via UPS. I will pack carefully. They can be picked up in central Iowa.
Thanks!
Luke M
#83 DS
Plaid Man is offline   Reply With Quote
Old 09-27-2017, 11:17 AM   #2
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
Please follow the Member Classified Rules (#2) or I'll delete the thread.
2. You must post AT LEAST ONE picture of the item(s) for sale with a sign included in the photo. On the sign, should be your username, date and the words FT86Club.com on it. It can be handwritten or printed on a piece of paper. No photoshopped signs will be accepted.
Thanks,
ichi
Old 09-27-2017, 10:22 PM   #3
Plaid Man
Here are some actual pictures...
The Following User Says Thank You to Plaid Man For This Useful Post:
ichitaka05 (10-02-2017)
Old 09-30-2017, 03:05 PM   #4
Joesurf79
Joesurf79's Avatar
Drives: 2016 White Pearl BRZ Premium
What spring rate are you currently running? Any idea what a rebud costs?
Joesurf79 is offline   Reply With Quote
Old 10-02-2017, 01:48 PM   #5
Plaid Man
I have stock springs on these for SCCA street class. Here are what the stock rates are:
Front: 23 N/mm (131 lbs/in)
Rear: 37 N/mm (211 lbs/in)
I think they are pretty reasonable to rebuild, but don't have a price. I'll check with MCS...
Old 10-02-2017, 02:01 PM   #6
Plaid Man
Just talked to MCS and they said a full rebuild would be $225 per shock. They also stated that this valving would be applicable to race springs in addition to the lower rate stock springs. The shocks have a lot of adjustment range.
Old 10-12-2017, 01:35 PM   #7
Plaid Man
Bump
Double Adjustable Ohlins? *teaser* FRSport.com Suspension | Chassis | Brakes -- Sponsored by 949 Racing 29 05-13-2016 01:06 PM
FS: MCS C-Street Double Adjustable Shocks with TRD Spring PKG simpleisbest Brakes, Suspension, Chassis 11 08-24-2015 01:41 PM
RCE Yellow springs with Koni Sport adjustable shocks TimR Brakes, Suspension, Chassis 7 03-05-2015 02:14 PM
Adjustable shocks+ springs vs Coilovers CyberFormula Suspension | Chassis | Brakes -- Sponsored by 949 Racing 44 06-08-2013 03:59 PM
Non-adjustable shocks? shawnperolis Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 03-26-2013 03:38 PM
