| Engine Swaps Discussion of engine swaps. |
Drives: 2JZ BRZ
Getting A/C to work
Im in the planning phase on doing a built 2jzge / 72mm turbo / cd009 trans with 8.8 rear end.
Has anyone gotten a/c to work? I will be running a haltech elite 2500 and was wondering if its possible. I know a simple way would be to wire the a/c request from eh factory button to the haltech and have the haltech output the signal to turn the compressor on but I'm guessing its more complex than that? The system would have to turn itself on/off and activate the fans from the condenser wouldn't it? And something tells me this is all controlled via can |
Drives: 2JZ BRZ
I took a closer look at the wiring diagram from a BRZ and it looks like the only two wires from the factory ecu are going to the clutch and the pressure switch after that the connection goes to the a/c amplifier.
anyone have input on this? |
Sorry, not very helpful, but I have AC working with Motec. In the Motec 86 harness wiring diagram, I do see only two connections related to AC: http://www.motec.com/filedownload.ph...pdf?docid=4504
Drives: 2JZ BRZ
Thanks! I never thought of looking at an ecu with a wiring loom already made for this car. It looks like the first one is a switched input that would be the a/c request from you pressing the button... and the second says A/C heater relay and that would be going to the negative side of the relay so that the ecu could switch it to ground and turn the compressor clutch on.
Im still trying to find information on this pressure switch and what it does |
#5 | |
I Love custom Turbo kits
Drives: Limited BRZ
Drives: 2JZ BRZ
it looks like ac request is going through CAN but everything else is wired from the ecu.
| new 2014 Wheels - RAYS VOLK Racing ZE40 | WORK Meister M1 | WORK Seeker Series | RavSpec | Wheels and Tires | 8 | 06-15-2014 10:07 AM |
| WORK Emotion Wheels ** Winter Promotion || Free WORK Lugs or WORK Caps ** | RavSpec | Wheels and Tires | 18 | 12-10-2013 05:19 PM |
| 18x9.5 +38 Work Emotion CR kai Work Metal Buff | Jive Turkey | Wheels and Tires | 22 | 05-20-2013 01:54 AM |
| Work Emotion CR Kiwami Bronze 18x8.5 +47 18x9.5 +38 (5x100) w/tires + Work lug nuts | serial gixxer | Wheels and Tires | 41 | 03-29-2013 03:14 AM |
