Old 09-25-2017, 12:00 PM   #1
szjalo
Drives: 2014 Scion FR-S
OEM usb port not charging cell phones (sometimes)
I have a 2014 monogram Scion Fr-s. one strange thing came across is the factory USB port (above the AUX , at the bottom of the head unit), sometimes, quits charging any device I connect to it. whenever this occurs, a message shows on the headunit screen like:
"Power consumption of USB device too high. USB device will therefore be turned off."
strange thing is that something the phone charges just fine and there is no error message on the screen, sometimes it doesn't. the latter case will cease and resume the charging process repeatedly every second which is super annoying. I tried to change the phone settings (turn off all apps, turn off fast charging etc.), nothing really solve the issue.
is the USB port's working amp fluctuating at different times?
Is there a solution to let the phone being charged?
Thanks in advance.
szjalo is offline   Reply With Quote
Old 09-25-2017, 02:25 PM   #2
darko
Drives: RAVEN FRS
USB port was not meant for charging. Only for music Depends on the current draw of the phone.
You could get a 12V- to usb car charger and just plug it in the glovebox socket
darko is offline   Reply With Quote
Old 09-26-2017, 10:19 AM   #3
allowe
allowe's Avatar
I charge my iPhone on it since day 1. It does charge it slow though.
To op, try changing the cord. What phone do you have? My USB port is a bit loose sometimes and does require shaking in order to make it work.
allowe is offline   Reply With Quote
Old 09-26-2017, 11:30 AM   #4
swarb
Like mentioned before, it isn't made for charging. It is probably .5amp... with a 3000mah phone it would take 6hours to charge from dead to max. And if you have it on it would probably take 8+ hours. While a 2.1 amp charger would take 1.5 hours.
Are you seriously going to risk burning up a head unit because you were too cheap to spend 5 bucks on a charger?
Old 09-27-2017, 02:33 PM   #5
Sovran
Drives: 2013 CBS BRZ-L 6AT
FWIW, I picked up a tester and found that all three power sources (USB near Aux, 12V in console, 12V in glovebox) put out the same crappy 0.x amps in my BRZ. (It might have been 0.4a, but I don't remember exactly.) So there's no real advantage in using the 12v ports.
There's a tiny chance that the amperage allowed by my CLA is exactly the same as the amperage allowed by the USB port. If anyone has measured and gotten different results than I did, I'd be very interested to hear it.
Sovran is offline   Reply With Quote
Old 09-28-2017, 02:21 AM   #6
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
it depends on the phone. iPhones usually charge but most if not all Android devices will not. Not sure why but my GF used to be able to charge hers and that isn't only in the FRS but also on an aftermarket deck in another car that has a USB plugin.
Can't use Bluetooth audio when I'm charging my phone through USB port Eddie Electronics | Audio | NAV | Infotainment 13 06-04-2014 11:54 PM
USB port charging issue unsurety Issues | Warranty | Recalls / TSB 2 05-17-2014 02:49 PM
Cell Phone Provider WRXGuy1 New England 15 11-06-2012 10:27 AM
Cell Phone Interference akuhei Issues | Warranty | Recalls / TSB 3 10-11-2012 04:35 PM
adding a second usb port for charging? Reason Electronics | Audio | NAV | Infotainment 5 07-11-2012 07:47 AM
