Old 09-12-2017, 02:40 PM   #1
brewdad16
Drives: currently shopping
New member - shopping - looking for info
Hi all, I'm strongly considering picking up a 13-16 FRS or BRZ to daily drive and also run in SCCA's new Spec autocross class that is coming out in 2018.
I searched and clicked around and didn't really find what I was looking for.
Does anyone have a scanned copy or links or whatnot to the original sales brochures for each of the twins? Curious to see what sorts of options could be selected as standalone, what comes in each of the various packages, etc.
Also, any common things to look for as potential signs of problems when shopping these cars would be great (buyer's guide type info).
Thanks!
- KB
FRS/BRZ Shopper - for SCCA autox SSC class
prior fun cars: 2010 RX8 R3, 2012 C6Z06, 1994 MR2 track car, 1991 MR2 street car, 1989 Fox Mustang
brewdad16 is offline   Reply With Quote
Old 09-12-2017, 03:33 PM   #2
https://www.google.ca/search?q=buyin...k1.sAEcdI4kvqU
Old 09-12-2017, 03:36 PM   #3
VoltsFRS2013
VoltsFRS2013's Avatar
Drives: 2022' GR86 Premium 6MT
From experience, go BRZ if you can. I personally think they are the better car and I currently drive a 13' FRS. If you decide to go the FRS route be sure to shop 14' and up.
22' Toyota GR86 - Trueno Blue - M/T (CURRENT)
18' Toyota 86 GT Black - Moonslate Gray - M/T (SOLD)
13' Scion FRS - Ultramarine - A/T (SOLD)
VoltsFRS2013 is offline   Reply With Quote
Old 09-12-2017, 03:51 PM   #4
strat61caster
strat61caster's Avatar
Pick the one with the interior you want, these cars are super basic and there weren't any meaningful performance options available that are SCCA allowed. The '13 FR-S will be a few lbs lighter due to a lack of leather, HID, touchscreen/navigation, heated seats, climate control, push button start etc. but that may not matter so much to you as the BRZ undoubtedly has the nicer features for very similar money and we're talking like 10-20 lbs. max, it won't be the deciding factor when it comes to autox like some other chassis that can easily gain 50+ lbs with 'factory' options that make a model of a chassis noncompetitive for street+street touring classes.
The only mechanical difference of consequence is spring rates which is irrelevant because you'll be running the spec springs. They are totally mechanically identical aside from the suspension spring rates and manufacturing tolerances.
There is a little wing available on the BRZ higher trim and Scion special models (all labeled 'Release Series' iirc) got "TRD" springs and sway bars which you'll be changing out anyway along with some of the features of the BRZ listed above.
The Scion bodykit (skirts, wings, etc.) was decided to be a dealer installed accessory (with the exception of the 'release series' bodies iirc) and as such won't be SCCA kosher. I'd avoid all body modifications except the OE BRZ spoiler just to not run afoul of the rules.
If you come across one that's questionable post it in one of the autocross threads, no SSC specific thread yet but if you put it in the CS/DS threads someone will likely be able to tell with good confidence if you're playing by the rules or not.
Buying a later model applies to both cars. IMHO I'd look for a '13 FR-S built in April 2013 or later because that's the interior I like the best with the revised tune that supposedly fixes direct injector seal failure. But my car put 60k miles on the 'bad' tune without issue so I wouldn't say no to an older one at the right price and mileage.
Edit: If you like the features a BRZ offers it is 100% worth the money as it's chump change vs. upgrading all that stuff on your own. Or griping about not having them.
ineedyourdiddly
The Following 3 Users Say Thank You to strat61caster For This Useful Post:
Cole (09-13-2017), Spuds (09-12-2017), VoltsFRS2013 (09-12-2017)
Old 09-12-2017, 09:05 PM   #5
If you go BRZ the same 14 and up applies since they are the same thing.
Gotta ask what makes the BRZ a "better" car?
86geek (09-13-2017), VoltsFRS2013 (09-13-2017)
Old 09-12-2017, 10:17 PM   #6
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
Most 13s are likely retuned to something more recent at this point. Scion did the whole 2 years free maintenance thing, so I would guess a reflash would have been done at first opportunity.
Old 09-12-2017, 10:22 PM   #7
Scuderia86
Drives: 2014 Scion FR-S
Two things:
1) Nicer interiors.
2) Slightly different suspension. If I'm not mistaken, the FRS is a bit more tail happy.
That said, I like my '14 FRS just fine. My driving style being what it is, I actually get some understeer on the racetrack.
(Understeer in an FRS... I know, right?)
Scuderia86 is offline   Reply With Quote
Old 09-12-2017, 10:46 PM   #8
strat61caster
No dealer would guarantee that they would flash the updated tune when I called them, I did 59k miles on the original tune before going aftermarket.
ineedyourdiddly
Spuds (09-12-2017)
Old 09-12-2017, 11:13 PM   #9
Cal3000
Drives: Panda FR-S
Originally Posted by Scuderia86 View Post
Two things:
1) Nicer interiors.
'13s are really tail happy. The suspensions is so stiff at the rear and the rebound in the shocks are too light which makes the tire bounce on the surface. That's why they are so drifty and a bit harder to control.
Vortech SC on 9psi Pulley, Invidia Catless Front Pipe, Invidia N1 Catback Exhaust
242whp/197ft-lb on Mustang Dyno (91 octane water)
284whp/223ft-lb on Mustang Dyno (E85)
Cal3000 is offline   Reply With Quote
Old 09-12-2017, 11:21 PM   #10
strat61caster
While I totally disagree, OP will be running the SSC class suspension package which totally negates this difference between models by using Eibach lowering springs and Koni Yellows.
ineedyourdiddly
Cal3000 (09-13-2017)
Old 09-13-2017, 01:44 AM   #11
Cal3000
Drives: Panda FR-S
I forgot it depends on your tire set up. lol.
It doesn't take too much effort to kick the tail out still. Tires such as Michelin PSS stick hard. Stock tires along with economy tires want to break traction any time it can.
With hard turns, it's easy to wheel hop.
Old 09-13-2017, 03:18 AM   #12
VoltsFRS2013
Interior quality
Old 09-13-2017, 03:43 AM   #13
HKz
Reformed
HKz's Avatar
Drives: '23 GRC, '11 Prius, '04 RAV4
psh, better interior = more weight, no need....frs all the way
HKz is offline   Reply With Quote
Old 09-13-2017, 06:31 AM   #14
Two things:
1) Nicer interiors.
Those make it different not necessarily "better".
86geek (09-13-2017)
Car Shopping... Mr. Banana Other Vehicles & General Automotive Discussions 25 09-23-2014 03:35 PM
Those who are still shopping for a BRZ HapaHaole Northern California 1 12-21-2013 02:40 PM
new member: shopping steelertown BRZ First-Gen (2012+) — General Topics 14 05-07-2013 07:54 PM
Brz Info/Specs (helpful info for questions asked often) Gaen BRZ First-Gen (2012+) — General Topics 0 05-24-2012 10:09 PM
Hi, new member/ Have some new info 2jz-gte4life Scion FR-S / Toyota 86 GT86 General Forum 24 04-01-2010 11:49 PM
