Old 09-12-2017, 04:04 AM   #1
alex87f
Meow
alex87f's Avatar
Drives: Focus ST mk4
Question Oil smell after cam plate fix?
'Morning everybody
I recently bought a used GT-86, and quickly noticed the well-known burning oil smell. Looked under the hood, and the cam plate was definitely leaking.
The car still being under warranty, Toyota did some work on it, and the cam plate leak now seems to be gone. However, when the engine is warm, I can still smell burning oil through the vents, especially when the HVAC's at faster speeds.
Those of you who had the leak fixed, did the smell go away immediately? The car has about 32 000 miles and I suspect the leak was present for most of those, so I was assuming there could be some oil residue on the overpipe / manifold that could still be burning off?
Also, it's worth noting Toyota pulled the engine out of the car and re-sealed a couple other areas.
Cheers,
Alex
alex87f is offline   Reply With Quote
Old 09-12-2017, 12:40 PM   #2
humfrz
Welcome to the forum ..........
I'd suggest you run it for a few miles (like 100) and see if the smell goes away ....... if it doesn't ...... check for more leaks.
humfrz
Old 09-12-2017, 01:18 PM   #3
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
I installed an oil pressure gauge a week ago or so and in the process I must have spilled a tiny bit of oil on the header because I smelled burnt oil for a week (200 miles or so). A little oil takes a long while to burn off, and it flows and can hide in a lot of nooks and crannies down there.
Old 09-12-2017, 02:19 PM   #4
DarkSunrise
DarkSunrise's Avatar
Take a clean rag and wipe underneath the cam plate. If you don't see any oil on the rag, you don't have an oil leak. But to answer your question, it will take a couple of cycles to burn the remaining oil off the exhaust/overpipe. You can speed up the process by getting the exhaust nice and hot (back to back pulls or 4th gear on the highway). I did that and the smell was gone after 2 trips.
2022 BRZ Build
2013 FR-S Build
Old 09-12-2017, 04:29 PM   #5
alex87f
Meow
alex87f's Avatar
Thanks for the responses
I did drive it very little since I got it back, about 30 miles so far, so I'll try running it a little longer.
I checked again this morning and saw no traces of the leak coming back, the bottom of the plate was still dry despite pulling the car higher into the rev range.
Old 11-08-2017, 06:36 AM   #6
alex87f
Meow
alex87f's Avatar
A quick follow-up (better late... you know). Oil smell is gone now, although it took a solid 2-300 miles to completely get rid of it.
Definitely an improvement
burning, oil leak, overpipe
Smell Gas? Skurj Issues | Warranty | Recalls / TSB 14 05-25-2020 11:05 AM
New Car Smell Frisco Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 35 02-28-2018 06:09 PM
Odd smell FloridaBRZ BRZ First-Gen (2012+) — General Topics 11 01-18-2015 01:49 AM
License plate covering front plate effect cooling? Wolfkiller Scion FR-S / Toyota 86 GT86 General Forum 4 05-04-2013 07:19 PM
[For Sale] Rho-plate Tow Hook Mounted License Plate rack pizzahead20 Canada Classifieds 0 08-23-2012 12:06 AM
