Old 09-12-2017, 12:57 AM   #1
leevanf
leevanf's Avatar
Drives: 2014 BRZ Limited A/T
How do you change the foglamp housing on the BRZ?
I recently bought this one :
https://www.diodedynamics.com/store/...category/1446/
and when i check online, the videos are usually replacing whole assemblies (which require maybe lifting the car up, and removing the bottom cover of the bumper) while others are just bulb changes which just need 3 clip removals.
Havent seen a video on chaging the housing only, will it be sufficient to just turn the tire and remove 3 clips in the wheel well to fit this thing?
leevanf is offline   Reply With Quote
Old 09-12-2017, 06:42 AM   #2
BirdTRD
Simply Forgotus
BirdTRD's Avatar
Drives: 2014 Supercharged SSM BRZ Limited
The housing comes out the same way as if you were changing the bulb, it's that easy. No need to remove the bumper, access it thru the fender liner.
BirdTRD is offline   Reply With Quote
Old 09-12-2017, 09:11 AM   #3
Stang70Fastback
A.K.A. Starlord
Stang70Fastback's Avatar
Drives: 2015 Series.Blue
This might be useful for you
http://www.seriesblueadventures.com/...led-fog-lamps/
Check out my blog, read all about my BRZ adventures, and oogle my sweet cell-phone photos!
You can also find me on Instagram, and on Facebook.
Stang70Fastback is offline   Reply With Quote
Old 09-12-2017, 09:11 AM   #4
Stang70Fastback
A.K.A. Starlord
Old 09-12-2017, 10:04 AM   #5
leevanf
leevanf's Avatar
Originally Posted by Stang70Fastback View Post
Thank you, and I am guessing what shipped to me had no adapters to h11 yet?
Old 09-12-2017, 10:32 AM   #6
Stang70Fastback
A.K.A. Starlord
Yeah, you need these:
https://www.diodedynamics.com/store/...ter-wires-pair
Old 09-12-2017, 10:47 AM   #7
JazzleSAURUS
Drives: 15 BRZ LTD, 05 FXT
I made this video a while back, it goes step by step and shows the housing differences.
[ame="https://www.youtube.com/watch?v=9we2tw18SKI"]BRZ Glass fog light upgrade - YouTube[/ame]
Your instinct is right, jack the front end up, pop the front wheels off, undo the pins holding the fender liners in place, and remove the housing, effectively.
Jake
SOLD: 2015 WRB BRZ Limited ('02 WRX BBS, S-04's, Stoptech Sport pads, MXP SP, AVO drop in filter, Mishimoto Intake tube, decatted header, OFT 93 Stage 2 EL Tune, Kartboy rear shifter bushing, Whiteline transmission and subframe lockout bushings, ST Coilovers, SPC Camber bolts w/smaller crash bolt, SPC LCA's & SPC Toe Arm bushings, Red TOMs, TRD Wing.)
JazzleSAURUS is offline   Reply With Quote
Old 09-12-2017, 12:16 PM   #8
leevanf
leevanf's Avatar
Thanks buddy, last question.. notice from my uploaded photo holding it, there are two wires, red and black, with ends seemingly covered in insulation. Do i just pull off the tubes of insulation and they go straight into the black sockets in the photo? or is there crimping and wiring to do? Im not sure how to "install" the wires into the included black PSX socket :P
Old 09-12-2017, 12:59 PM   #9
Stang70Fastback
A.K.A. Starlord
No crimping. They will snap in. I wouldn't do anything, though, until you get the adapters. You need to see which way the adapter plugs in, and then see which way that PSX socket connects to the adapter, and make sure you insert the red and black wires into the right side - otherwise it's a HUGE PITA to get those wires back out once you clip them in (ask me how I know...)
But yeah, no crimping. They snap in.
Old 09-12-2017, 11:37 PM   #10
leevanf
leevanf's Avatar
Thanks so much!!
PTE 6466, 1.0 divided A/R, polished comp housing, black ceramic turbine housing slicktop Engine, Exhaust, Bolt-Ons 6 10-17-2015 10:53 PM
Oil Change Interval Change (Subaru recommended) Flow Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 34 09-10-2014 07:27 PM
MAF Housing g0lden Engine, Exhaust, Transmission 1 12-31-2012 09:46 PM
Can someone with a BRZ limited measure the foglamp size (housing not bulb) Norkoastal Cosmetic Modification (Interior/Exterior/Lighting) 0 08-27-2012 11:31 PM
JPN Subaru Foglamp housing - DRL Delete Available? Norkoastal Cosmetic Modification (Interior/Exterior/Lighting) 0 08-23-2012 07:38 PM
