Old 09-11-2017, 02:53 PM   #1
retepK
Drives: 2013 Brz Limited
Te37SL Lug nuts
Hey guys,
New to the car scene. Recently picked up a pair of te37 SL in 18x9.5 and was wondering if I needed to get aftermarket lug nuts. I looked around on different forums and couldn't seem to get a solid answer. Was wondering if I could just use the stock lugs or if aftermarket ones were required.
If aftermarket ones are required which ones did you go with?
Kindest Regards
Peter K.
retepK is offline   Reply With Quote
Old 09-11-2017, 02:56 PM   #2
TylerLieberman
TylerLieberman's Avatar
Drives: '24 GR86
Aftermarket
TylerLieberman is offline   Reply With Quote
Old 09-11-2017, 03:31 PM   #3
housecat
Computer Scientist
housecat's Avatar
Drives: 2014 BRZ Limited
Try the stock lug nuts on your Te37S before buying anything. They aren't acorn shaped so they will work. The only problem is that they might be too short / there's not enough clearance for a socket to tighten them down. But if your socket fits, then stock lug nuts should be fine.
I'll just mention that I bought Muteki SR48 lug nuts for RPF1s because stock lug nuts were too short to get my wrench on them. Those lug nuts started rusting after just a month, even though my car is kept in a garage and hasn't seen any snow/salt/coast.
Keep calm and drive safe
housecat is offline   Reply With Quote
Old 09-11-2017, 04:03 PM   #4
mrg666
pessimistic skeptic
mrg666's Avatar
I used these, and they work fine.
https://www.amazon.com/gp/product/B001O08ADO
Old 09-12-2017, 04:44 AM   #5
EndlessAzure
Wheels for Brains
EndlessAzure's Avatar
I use Muteki SR35 on my Rays Gram Lights 17x9, and they were affordable, have the right seat, and were a good length for the job in my case
Like others have said, the OEM ones appear to have the right 60 degree taper so you can use them in a pinch.
Any reputable aftermarket lug nut with a proper 60 degree taper should serve you fine for keeping the wheel on. However, there are other considerations to be made like open ended versus closed ended, locks, rotating seat, aluminum vs steel vs ..., among other attributes.
If you want to go the extra mile and protect your investment, Project Kics R40 Iconix with caps are a good bet. However, you'll have to shell out a decent penny for them.
If you are really in doubt about what will and will not work, you can't go wrong with Rays standard hex lug nuts (though again they are a little pricey).
EndlessAzure is offline   Reply With Quote
Old 09-12-2017, 08:43 AM   #6
NINE
Drives: 2015 BRZ
I used the stock lugs on with my TE37sl's just fine.
Daily: 2008 IS250 (Stock)
Toy: 2015 BRZ (KW V3, TE37sl) More to come.
Past: 2008 BMW M3, 1976 Datsun 280z, 1998 240sx, 1990 180sx, 2005 RSX-S, 2003 IS300, 2001 Civic.
NINE is offline   Reply With Quote
Old 09-12-2017, 10:06 AM   #7
TylerLieberman
Drives: '24 GR86
Gross.
Old 09-13-2017, 07:50 AM   #8
keb86
Drives: Toyota 86
you can't go wrong with Mcgard lugnuts
keb86 is offline   Reply With Quote
Old 09-13-2017, 06:04 PM   #9
why?
Only happy when it rains.
why?'s Avatar
Drives: series.blue
I prefer these because aluminum, light, and blue.
FS:TE37SL peebking Wheels and Tires 1 01-29-2016 10:00 PM
TE37sl BluLightning Wheels and Tires 13 11-21-2015 07:52 PM
Volk TE37SL 18x9.5 +22 5x100 Gunmetal w/ tpms, neochrome lug nuts, H&R 15mm spacers fe Wheels and Tires 4 02-10-2015 01:38 PM
Te37sl in bronze ? diss7 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 08-24-2013 03:25 PM
