Old 09-04-2017, 07:39 PM   #1
noonedoesnt
Drives: 2016 Toyota 86 GTS - Manual
Installed catless UEL BORLA headers, got a CEL that you wouldn't expect (NOT P0420)
Hi guys, last friday I installed BORLA UEL catless headers, and got a CEL light 2 days later, code P0171, for 'running lean'.
There are MANY others using the same tune im running (A stage 2 UEL catless tune, with delayed low load ignition for pops/bangs out exhaust).
However, i'm pretty sure I have a leak from the passenger side (AUDM) header gasket (which sounds a bit like a puff/ticking sound).
My question is, would I have gotten this CEL code due to having this leak?
Cheers
noonedoesnt is offline   Reply With Quote
Old 09-04-2017, 10:13 PM   #2
Apoc
Apoc's Avatar
Drives: Raven FR-S 6M
Yes the CEL is likely related to the exhaust leak. The front sensor is seeing higher O2 than expected (AFR) and has maxed out LTFT. Once the ECU can't adjust fuel trims any further it will throw that code. You may also notice that the exhaust is actually smelling super rich.
“The World is Flat”
[||•]=(86)=[•||]
Apoc is offline   Reply With Quote
The Following User Says Thank You to Apoc For This Useful Post:
mav1178 (09-05-2017)
Old 09-04-2017, 10:21 PM   #3
noonedoesnt
Originally Posted by Apoc View Post
Yes the CEL is likely related to the exhaust leak. The front sensor is seeing higher A/F ratios and has maxed out LTFT. Once the ECU can't compensate AFR any longer it will throw that code. You may also notice that the exhaust is actually smelling super rich.
I just checked it out, and here is the result:
[ame="https://www.youtube.com/watch?v=bSF9nc62WuE"]Leak1 - YouTube[/ame]
Part in the video is show in this pic:
https://image.ibb.co/nqUvwv/header.png
Old 09-05-2017, 08:24 PM   #4
noonedoesnt
bump
Old 09-05-2017, 08:40 PM   #5
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Originally Posted by noonedoesnt View Post
bump
Dude, the answer was already given to you.
Do you want more people to confirm? If yes, please reply with the number of replies you want to get so we can answer your question definitively.
The Following User Says Thank You to mav1178 For This Useful Post:
why? (09-07-2017)
Old 09-05-2017, 08:43 PM   #6
noonedoesnt
Yes I would like some more people to confirm, that was the purpose of the bump. Maybe someone else has had the same experience.
Old 09-05-2017, 09:04 PM   #7
mav1178
mav1178's Avatar
https://www.google.com/search?q=p0171+code
You already confirmed you have a leaking header so it's really up to you if you want to accept the diagnosis and fix it, or leave it as-is while you wait for internet keyboard warriors to confirm or not.
But if you want to build up your confirm karma points, my answer is yes.
why? (09-07-2017)
Old 09-05-2017, 09:08 PM   #8
Pointmutation
Pointmutation's Avatar
Drives: 2016 ZC6
bump
Bump for what? Did you fix the leak yet? You still have the code after the leak got fixed?
Pointmutation is offline   Reply With Quote
The Following User Says Thank You to Pointmutation For This Useful Post:
why? (09-07-2017)
Old 09-05-2017, 09:13 PM   #9
Tor
Tor's Avatar
Drives: Toyota GT86
Did you use new gaskets? Did you tighten the nuts with a torque wrench with the correct torque?
Get off the internet and go fix your exhaust leak.
Tor is offline   Reply With Quote
The Following User Says Thank You to Tor For This Useful Post:
why? (09-07-2017)
Old 09-05-2017, 09:14 PM   #10
noonedoesnt
I will do lol. Just wanted some more confirmation in the meantime, as I can't fix it for a few days.
Old 09-05-2017, 09:25 PM   #11
mav1178
mav1178's Avatar
Bump for updates.
The Following 6 Users Say Thank You to mav1178 For This Useful Post:
86geek (09-20-2017), bababooey (09-06-2017), Cole (09-06-2017), D_Thissen (09-07-2017), Tor (09-05-2017), why? (09-07-2017)
Old 09-05-2017, 09:29 PM   #12
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
Got same code, ignored it.
Car now has AIDS.
The Following 2 Users Say Thank You to x808drifter For This Useful Post:
Cole (09-06-2017), why? (09-07-2017)
Old 09-06-2017, 09:28 PM   #13
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
Cheers
Yes
The Following User Says Thank You to guybo For This Useful Post:
why? (09-07-2017)
Old 09-06-2017, 10:55 PM   #14
noonedoesnt
Ok tried tightening that nut, but its very hard to access, managed maybe a quarter turn of tightening with a spanner, and the leak sounds like it halved in loudness.
Any downsides to using gasket sealant to finish off?
Installed Borla UEL Headers last Friday. Got CEL, then CEL disappeared. IvanPwns Engine, Exhaust, Transmission 7 09-07-2017 06:13 AM
Catless UEL + Tune...Still Get P0420 Michael Engine, Exhaust, Transmission 18 07-19-2016 04:33 PM
Installed Borla UEL Headers, crazy rasp. Need Help. CodyFRS Engine, Exhaust, Transmission 39 04-19-2016 04:14 AM
Which headers? Borla Equal Length or FA20club catless? Norcalmav23 Engine, Exhaust, Transmission 5 05-25-2013 04:59 PM
