Old 09-01-2017, 07:02 PM   #1
TofuJoe
Ohne Titel
TofuJoe's Avatar
Drives: 2017 BRZ PP ISM
Passenger Dash Trim Interchangeable Between Model Years?
I bought a BeatSonic QBP13 phone mount for my 2017 BRZ. Popped off the passenger side dash trim. The construction of the panel is slightly different from previous model years? There are ridges on the interior of the dash panel that prevent the BeatSonic phone mount from working.
I could dremel the ridges out on the panel, but I don't want to screw it up. It's a $90 part.
Does anyone know if the panels from previous years will fit on a 2017?
I saw that FT86SpeedFactory has an OEM black passenger trim piece for $38. Maybe that will work?
http://www.ft86speedfactory.com/toyo...l#.Wanm1K2ZMUE
TofuJoe is offline   Reply With Quote
Old 09-01-2017, 09:00 PM   #2
Originally Posted by TofuJoe View Post
I bought a BeatSonic QBP13 magnetic phone mount for my 2017 BRZ. Popped off the passenger side dash trim. The construction of the panel is different from previous model years. There are additional ridges on the interior of the dash panel that prevent the BeatSonic phone mount from working.
I believe that the 17s have have one piece pad? If so then it won't work. Might just be the Canadian ones though. Geeez I was no help at all here.
Old 09-02-2017, 09:58 AM   #3
TofuJoe
Ohne Titel
TofuJoe's Avatar
It's 2 pieces. BeatSonic said the mount should fit if I trim the plastic piece on the back shown in the attached photo & diagram.
Old 09-05-2017, 11:41 AM   #4
TofuJoe
Ohne Titel
TofuJoe's Avatar
Update: For anyone with a 2017 BRZ Limited who is considering the BeatSonic phone mount, you'll need to do some dremeling to make it fit. The left edge that the phone mount goes around was too tall (far right edge under the wrap in the image above). After trimming it down, the mount works great though.
I popped off the built in mount base and replaced it with a Scosche magic mount: http://amzn.to/2wCqHCA
Really happy with how it turned out.
Old 09-05-2017, 12:04 PM   #5
Azzudien
Drives: 2017 Series Yellow BRZ
Canadian cars have the one piece dash, American cars do not. I actually bought a Canadian dash panel already so I can change the HU and it fits right into the American car.
Azzudien is offline   Reply With Quote
Old 09-05-2017, 01:47 PM   #6
TofuJoe
Ohne Titel
TofuJoe's Avatar
FT86SpeedFactory thinks the black dash trim should work on a 2017, if the radio bezel and dash piece are separate pieces in your country.
http://www.ft86speedfactory.com/toyo...l#.Wa7jQK2B0UF
Interior trim trim clips (Dash Trim Panel) ubersoph Cosmetic Modification (Interior/Exterior/Lighting) 4 08-11-2022 07:47 AM
FRS dash piece interchangeable with BRZ???? RB-BRZ BRZ First-Gen (2012+) — General Topics 7 10-10-2016 02:42 AM
Aluminum head unit trim and passenger airbag trim? WallsAndFoundations Cosmetic Modification (Interior/Exterior/Lighting) 0 08-24-2014 02:39 AM
WTT: My FR-S black dash trim pieces for your BRZ silver dash trim pieces. Tim_Asphalt_FRS Interior Parts (Incl. Lighting) 1 05-13-2013 06:25 PM
What Would You Like to See for future model years? Jordo! Scion FR-S / Toyota 86 GT86 General Forum 52 08-10-2012 02:10 PM
