Old 08-24-2017, 05:57 PM   #1
Zentec
Drives: 2017 Toyota 86
Stock clutch
On the 2017s is there a way to increase the feel of the clutch peddle? I've got almost 6k miles on the car and the peddle always feels light. I would like to know if there is an adjustment the dealer can make or is that just how it is. There is nothing mechanicly wrong it drives and shifts perfect.
Zentec is offline   Reply With Quote
Old 08-24-2017, 06:00 PM   #2
ApexEight
Drives: 2014 Subaru BRZ Limited 6MT SSM
Search how to take out the clutch spring. It'll feel pretty heavy at first, but you'll get used to it. The added feel and feedback is great. You can also adjust the height of the clutch pedal. Most people adjust it slightly below the plane of the brake pedal. It'll feel super short at first, but you'll also get used to it.
ApexEight is offline   Reply With Quote
Old 08-24-2017, 08:51 PM   #3
ApexEight
Originally Posted by sugoi View Post
Taking the clutch spring out completely supposedly accelerates wear on the seals of your clutch master cylinder.
MTEC Industries sells a replacement clutch spring that is said to increase the feel of the clutch.
Never heard that before. Interesting, although I don't see how it would accelerate wear on the slave cylinder.
I've heard good things about the MTEC clutch spring as well as their shifter springs.
Old 08-24-2017, 09:02 PM   #4
Jakinit
Drives: 2017 CWP BRZ Limited (MT)
Source.
Sent from my Pixel XL using Tapatalk
Jakinit is offline   Reply With Quote
Old 08-24-2017, 09:57 PM   #5
Zentec
Thank you I will look into the spring. Besides that is there anything else that can help?
Old 08-24-2017, 10:21 PM   #6
Ultramaroon
not playing cards
Ultramaroon's Avatar
Bullshit. Pure snake oil marketing bullshit.
Enjoy.
http://www.ft86club.com/forums/showthread.php?t=77390
Old 08-24-2017, 11:11 PM   #7
Ultramaroon
not playing cards
I agree. I'm skeptical as well.
I know that lots of people swear by removing the spring but I've lost count of how many people I've helped swap their slave cylinders. Simply removing the spring is just a tease.
The stock clutch will always be weird with how it fully engages in the last smidgen of travel but, at least with the slave swap, that vague in-between-ness is much shorter.
Old 08-25-2017, 12:15 AM   #8
humfrz
Oh, I suggest you just get used to it .....
See ....... how easy that is ......
humfrz
Old 08-25-2017, 12:24 AM   #9
Ultramaroon
not playing cards
No
Old 08-25-2017, 12:58 AM   #10
humfrz
No
OK, do it the hard way ........ old man ......
My philosophy is that since the clutch on this car doesn't feel like the clutch on my last car, nor will it feel like the clutch on my next car ........ I'm not gonna fight with it ......
humfrz
Old 08-25-2017, 01:14 AM   #11
Ultramaroon
not playing cards
My philosophy is that the clutch on this car felt like shit until I fixed it. Now every time I shift, instead of feeling disgust, I feel true joy.
...and a little sad for people who give in and just decide to "get used to it."
Old 08-25-2017, 01:26 AM   #12
humfrz
Well, it only took me about 10 shifts to ..... get used to it ...... maybe I was preoccupied on how to shift a 6 speed (coming from a 5 speed), since I only have four fingers and a thumb on my shifting hand ......
humfrz
Old 08-25-2017, 02:14 AM   #13
Zentec
I will defiantly look in to slave swap and mtec spring. I am not going to just remove the spring that is not a fix and can lead to problems.
When bleeding the clutch and you add the motul 600 fluid is mixing that with the stock fluid ok ? Will it change the feel or have any negative effects on it?
FS: Stock brake lines, stock clutch line, stock motor mounts Agent_D Brakes, Suspension, Chassis 4 08-22-2017 12:24 PM
Stock Clutch SirSpectre Engine, Exhaust, Transmission 9 10-02-2015 05:37 PM
FS: Stock Clutch Germanjap Transmission and Driveline 1 09-19-2015 02:37 PM
ACT clutch and LWF or stock clutch and Evolution industries LWF Hawk77FT Engine, Exhaust, Transmission 13 12-21-2014 02:14 AM
Stock clutch $50 obo PineappleFriedRice Transmission and Driveline 2 11-25-2013 01:21 PM
