Old 08-23-2017, 11:07 AM   #1
Firecruiser
Drives: 2014 brz
A/T fluid change gaskets
I'm trying to figure out the part numbers for the 3 a/t gaskets that i need for my fluid change. I tried searching the forum i can find a lot of topics discussing fluid but nothing that lists the A/T gasket part numbers. The diagrams on most of the parts websites don't show correctly for me and the subaru dealer is less than helpful they can't even tell me an accurate price for them to change the fluid. I've been told a range of guesses from $250 to $500(toyota dealer). All of the dealers around me a clueless with this car.
Firecruiser is offline   Reply With Quote
Old 08-23-2017, 11:12 AM   #2
Silver Cervy
*Some really cool title*
Silver Cervy's Avatar
Any specific reason for changing the fluid? Our autos are cvt's and as far as I know the fluid does not ever need to be changed. You're probably having a hard time finding info about it because no one ever does it.
Dealership should know though. Try a different one and contact Subaru directly if you can't get an answer from a technician.
Silver Cervy is offline   Reply With Quote
Old 08-23-2017, 12:08 PM   #3
Vital
Drives: 2015 BRZ
Just go to the dealer and tell them you need a crush washer for the transmission or differential whatever you are trying to change.
Not really sure where you heard that. Im pretty the manual says to change it at 60,000 or 100,000 miles i cant remember. Also, the ATs do not have CVTs its just a regular automatic trans.
Vital is offline   Reply With Quote
Old 08-23-2017, 12:18 PM   #4
Firecruiser
Drives: 2014 brz
Ya definitely not a CVT.
I'm rolling over 60,000 so its due to be changed. I'll try another dealer today see if they can get me part numbers for those washers.
Old 08-23-2017, 12:27 PM   #5
Vital
Drives: 2015 BRZ
Try these part numbers its worth a shot.
Differential fill plug gasket: SU00300122
Differential drain plug gasket: 1215710010
Old 08-24-2017, 12:44 AM   #6
Silver Cervy
Damn, I specifically asked my technician about trans fluid change a while ago, and he told me "it's a cvt so you never need to do that". These guys must really not know much about BRZ's.
Issues after AT fluid change 8enj1 Engine, Exhaust, Transmission 4 07-26-2016 07:06 PM
AT fluid change when going FI? xsnapshot Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 7 05-31-2016 07:03 PM
AT Fluid Change? Estey Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 45 10-23-2014 09:55 PM
AT Fluid Change Terrapin77 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 4 08-29-2013 09:52 PM
Fluid change siXXtoes Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 3 12-06-2012 09:39 AM
