Old 08-21-2017, 06:27 PM   #1
Raizokaze
Drives: 2013 scion frs
Has anyone use tein basis z coilover system?
And how was it? Ive been looking into rce yellow spring + bilstein b6 as i heard its good for daily and performance 🤔
Raizokaze is offline   Reply With Quote
Old 09-05-2017, 11:28 AM   #2
GoZ21
GoZ21's Avatar
Drives: 2013 Asphalt Frs
Theres a decent compilation of suspension setups that have been reviewed on here, best bet is to search in this forum for the answer your looking for. IMO the teins (im assuming you just mean the basis coilover NOT the flex Z) are fine if you want the aesthetics of a lower car with SOME performance. Running a coilover with dampening adj. makes a big difference if its a daily so you can soften your ride if you want and the basis only has height adj. you also have to use your factory top hat which can be a issue for some.
GoZ21 is offline   Reply With Quote
Tein Street-basis Slammillionaire Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 07-26-2017 04:15 PM
Tein Basis Z vs. Springs? max20s14 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 12 12-09-2016 12:17 PM
(LA/OC) FS: Tein Street Basis xais Brakes, Suspension, Chassis 1 05-05-2016 06:07 PM
NY: F/S Tein Street Basis jammz Brakes, Suspension, Chassis 5 04-20-2013 09:31 PM
Tein Street Basis coilover, Koni struts and shocks JoeBoxer Brakes, Suspension, Chassis 6 12-25-2012 09:43 AM
