Old 08-19-2017, 07:40 AM   #1
churchx
churchx's Avatar
Drives: 2014 GT86
15" wheels that fit over stock brakes
From recent thread of winter tire choice and from very scarce choice (of one) confirmed model of VW Avus 15" 15x6 +38 wheels decided to ask everybody so wheel directory maintainer can populate it with more choices:
- So, what other 15" wheels do clear our stock brakes (and suspension parts, as eg. on tire-rod ball join) from your experience?
I'm sure, for many twins might be not the only cars they have, so why not check, if wheels from the other cars fit?
Would be nice to see posted full size including offset, if available also pic (but non mandatory, design can be googled up if needed, it's confirmed fitment that matters), so that it can be added up to wheel directory.
Worth to note, if there are some specifcs that matter (eg. ball-seat lug adapters needed for VW, or if spacer needed, of what thickness)
As most going 15" very probably will do that for winter use (cheaper tires then even for 16", even narrower tire selection available) and supposedly twins having front wrx brakes, i guess, that some of winter rally wheels for wrx-es have great chance of fitting. Many of those are also easy to get/order world-wide.
Unfortunately despite for twins being around for already few years there is still not made by anyone brake template for stock brakes that might ease/simplify wheel-brake clearance check , and in same fashion as there is no template, there is nothing to be sent to wheel vendors/shops to confirm fitment remotely prior order - can someone take up this endeavour and finally make one? That should be of great help to many.
So far i know of only (except those VW Avus wheels):
15x6.5 ET40 Dodge Neon wheels & Also some 15" Toms wheels (width? offset?)
What wheels might be these?
Old 08-19-2017, 08:40 AM   #2
Slammillionaire
Slammillionaire's Avatar
Drives: 2013 Hot Lava FRS
Maybe rpf-1s?
Slammillionaire is offline   Reply With Quote
BACK TO STOCK SALE (WHEELS, COILOVERS, TRDBODYKIT, LIGHTS,BRAKES,MORE ) SpecPer Exterior Parts (Aero, Lighting, Etc.) 20 09-04-2015 09:42 AM
BACK TO STOCK SALE (WHEELS, COILOVERS, TRDBODYKIT, LIGHTS,BRAKES,MORE ) SpecPer Engine, Exhaust, Bolt-Ons 51 09-02-2015 04:16 PM
BACK TO STOCK SALE (WHEELS, COILOVERS, TRDBODYKIT, LIGHTS,BRAKES,MORE ) SpecPer Audio/Visual, Electronics, Infotainment, NAV 8 07-02-2015 09:54 PM
BACK TO STOCK SALE (WHEELS, COILOVERS, TRDBODYKIT, LIGHTS,BRAKES,MORE ) SpecPer Wheels and Tires 10 05-31-2015 12:16 PM
Stock brakes too small for stock wheels ndsleep612 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 44 04-11-2014 09:24 PM
