Old 08-15-2017, 09:05 AM   #1
moliver
Drives: FR-s
Header or E-85
Should I do a header and a tune or flex fuel and a tune.
Both is not a good answer.
moliver is offline   Reply With Quote
Old 08-15-2017, 09:18 AM   #2
BWilky
BWilky's Avatar
Drives: 2016 Subaru BRZ WRB
Do you want sound or power?
BWilky is offline   Reply With Quote
Old 08-15-2017, 09:21 AM   #3
moliver
Drives: FR-s
power
Old 08-15-2017, 11:40 AM   #4
bfrank1972
Drives: 2013 FR-S Argento
Are you able to run e85 all the time? If so, then run a header and e85 and forget spending money on a flex fuel kit. Just did two different tunes, one for gas, one for e85 and switch when the tank is empty. It's a little less convenient but is doable if you are able to run E85 all the time. If not, then I'd still say header, but a nice quality used header off the classifieds here.
Sent from my SM-N920V using Tapatalk
bfrank1972 is offline   Reply With Quote
The Following User Says Thank You to bfrank1972 For This Useful Post:
smg1138 (08-15-2017)
Old 08-15-2017, 11:46 AM   #5
moliver
Drives: FR-s
You think its worth the money for that Ace 250?
Old 08-15-2017, 12:39 PM   #6
B T
Is it nice? yeah. do you need an Ace 250 header? Not unless you're trying to pull every ounce of power out of it. For that kind of money you could go with a cheaper header and flex fuel.
B T is offline   Reply With Quote
Old 08-15-2017, 12:42 PM   #7
moliver
Drives: FR-s
you vote header over e-85 flex ?
Old 08-15-2017, 12:45 PM   #8
Submarinesonce
Drives: Frs
id do the header and tune first. you can always flex fuel later
JDL UEL Turbo GT2860RS, AP Racing BBK, Verus Splitter/diffuser/canards, Sard rep carbon wing, TFF bash bar, HKS hi power, Tein Flex A, Hotchkiss FSB, Radium MCB, Konig Hypergram 17x8, FS Indy 500, 6k HID, Whiteline trans bushing insert, Verus AOS, grimmspeed strut brace, Racerx oil cooler w/ setrab 619, ES steering rack bushings, Whiteline subframe bushings, Toms tails, STi mirror caps, IRP shifter, TRD Steering wheel
Submarinesonce is offline   Reply With Quote
Old 08-15-2017, 01:04 PM   #9
bfrank1972
BT hit the nail on the head - the ace headers are one of the best on the market, but there are other premium headers out there that don't quite get all the hype but perform nearly as well. I run a P&L EL long tube header and it's amazing. Big surge of power where the torque dip used to be, and a nice surge above 5500 as well. Sounds great, great build quality, option for a cat, and you can probably pick one up used from the classifieds for around 400-500 shipped. Tomei is another good brand that gives great performance with less investment, although I think I'd still prefer the long tube design of the P&L I have. Also Tomei had both EL and URL options - if you prefer the UEL sound then that might be a good option. Open flash header is another good UEL option for reasonable money.
If I were you,I'd go header and tuning first. Then if you want to run e85 all the time you just need to have a tune for both and switch. If you tune with an OFT, the tunes are free for both pump and E85. If you want to go flex fuel you can do that later for convenience. You can put the extra money into other things like rear diff upgrades, suspension upgrades, starter budget for FI
Old 08-15-2017, 03:18 PM   #10
brzaapi
CAR-AHOLIC
brzaapi's Avatar
Drives: 2018 BRZ Ts - CWP
Both, is the right answer...but since you don't like that let me add what I can.
I will attack this as what order you should do both these mods in.
1. Header (unless you have to worry about state emissions test, then FLEX first)
2. Flex/Tune
The header should be first as long as there is not a practical reason to hold off (emissions being one of those reasons). Then later when you have more scratch you can go Flex Fuel along with header. Header/tune/Flex is a great combo and I highly recommend it.
As for headers, I have purchased ACE heads twice. The fact that I went back to buy a second one should say something. But I am in a position where making the jump from $700 to $1500 for a header doesn't bother my budget. So buy the best header you can afford, and you will not have any regret in buying. Tomei is great, its what I used to run before ACE. I can't fault the header at all, especially for the money.
So...
1st - Header & tune
2nd - Flex/E85
Header choice - pick a price point, buy the best in that price point.
Best of luck in your build.
Track Toy - 2018 BRZ Ts - CWP
Daily: Audi TT RS
DD/4WD - Colorado ZR2 Bison - Mallett Supercharger
brzaapi is offline   Reply With Quote
The Following 3 Users Say Thank You to brzaapi For This Useful Post:
86 South Africa (10-10-2017), jubella2 (08-15-2017), Tcoat (08-15-2017)
Old 08-15-2017, 09:51 PM   #11
Turdinator
Señor Member
Turdinator's Avatar
Header and a tune. If you can't afford the tune as well as the header then just go flex fuel.
JDL also make some damn nice headers and are cheaper then the ACE offerings.
1974 TA22 Celica
2013 86 GT
Old 08-15-2017, 10:17 PM   #12
TruRace
TruRace's Avatar
Drives: FRS-Raven-MT
I think a header will do a lot for drivability as it should level out the torque dip.
I started with E85 first and did the header later. Didn't really notice an increase in power with the header but the torque dip was gone for the most part marking the car much more enjoyable driving around.
TruRace is offline   Reply With Quote
The Following User Says Thank You to TruRace For This Useful Post:
Jasonb (10-10-2017)
Old 08-16-2017, 12:51 AM   #13
Euro7R
Drives: 2013 Subaru BRZ
I did header and tune. Wish I did it way sooner instead of 4 years later.
It has provided the extra power that makes daily driving much more enjoyable.
Euro7R is offline   Reply With Quote
Old 08-16-2017, 10:41 AM   #14
Lunatic
Lunatic's Avatar
Drives: 2015 Raven FRS
I have the Delicious Flex Fuel kit and my car loves e-85. Runs so much better on e-85, not just more power but smoother all around. But I love the versatility of being able to still use gas on road trips where e-85 is not available.
Lunatic is offline   Reply With Quote
The Following User Says Thank You to Lunatic For This Useful Post:
Tcoat (08-16-2017)
JDL UEL header/Nameless header-back exhaust (Atlanta area) carbon_raven Engine, Exhaust, Bolt-Ons 16 05-09-2015 03:26 AM
Who has Open Flash Header (or aftermarket UEL header) in the GTA with stock exhaust? alanhung85 CANADA 6 10-21-2014 11:41 PM
RevWorks UEL Header + Nameless Catted Front Pipe VS Stock Gutted Header + FP NickFRS Engine, Exhaust, Transmission 44 04-19-2014 06:42 PM
Top Gear Solutions| HKS Header |Borla EL & UEL Headers| Agency Power Header| + MORE! TopGearSolutions Engine, Exhaust, Bolt-Ons 82 04-14-2014 09:16 PM
Gutted cat stock header vs aftermarket catless header NA application stevo585 Engine, Exhaust, Transmission 8 04-04-2014 05:12 PM
