Old 08-14-2017, 08:53 PM   #1
jvincent
jvincent's Avatar
PSA: Check your coilovers!
Since this just happened to me, just a reminder for everyone.
I was putting on new brake pads before a track day this weekend and I had a noise in the front left last time out that I though might be a wheel bearing going bad so I was checking for that.
It turns out the locking collar on my coilover was loose. Yikes! That's now been added to the check list for track prep.
The Following User Says Thank You to jvincent For This Useful Post:
Tcoat (08-15-2017)
Old 08-14-2017, 10:13 PM   #2
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Yep. Had the same thing happen and seems more common then one would think
Tcoat (08-15-2017)
Old 08-14-2017, 11:11 PM   #3
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Most (new) people owning coilovers don't know that they need to check the spring collars at least once a month.
The Following 4 Users Say Thank You to mav1178 For This Useful Post:
strat61caster (08-14-2017), Tcoat (08-15-2017), wparsons (08-15-2017), x808drifter (08-15-2017)
Old 08-14-2017, 11:12 PM   #4
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
Weird. This was not communicated to me by the specialty suspension placed that installed my $2,500 coilovers. Wtf.
Originally Posted by humfrz
I'm old and lazy
Old 08-14-2017, 11:47 PM   #5
strat61caster
strat61caster's Avatar
racecar parts = racecar maintenance
regardless of price point
edit:
fwiw most coilovers have a relatively reliable and trustworthy locking mechanism that should be moderately set it and forget it, but I would absolutely make sure it was still snug sometime mid-summer and break the locking mechanism loose and clean the coilovers every "winter" at a minimum.
that's my thought process for those of us in super mild climates where "winter" means "under 60 degrees F"
Frequent wheel changes and brake inspections make it routine to inspect, but if you're the kind of person who goes all year without pulling a wheel off I can see problems creeping up like they did on the OP. For instance, I know my sway bar endlink is loose on the left front, I can feel it, it's been about 4 days and I'll fix it tomorrow morning before I go to work. When I've got the wheel off I'll be giving the spring perches a tug to make sure they're still locked down and I'll be giving the damper body a good shake to make sure the top hat is all snug still as well.
ineedyourdiddly
The Following 6 Users Say Thank You to strat61caster For This Useful Post:
Clipdat (08-15-2017), dattran86 (08-15-2017), Tcoat (08-15-2017), Ultramaroon (08-15-2017), wparsons (08-15-2017), x808drifter (08-15-2017)
Old 08-15-2017, 12:27 AM   #6
Ultramaroon
not playing cards
Ultramaroon's Avatar
Drill & safety wire.
strat61caster (08-15-2017), Wally86 (02-16-2022)
Old 08-15-2017, 12:38 AM   #7
e1_griego
e1_griego's Avatar
Drives: Many
Also helps if you have a radial bearing in the upper spring perch as it lets things move a little bit more freely and doesn't try to unlock the collars when you turn.
e1_griego is online now   Reply With Quote
The Following 3 Users Say Thank You to e1_griego For This Useful Post:
RJasonKlein (08-15-2017), Scargod (02-15-2022), wparsons (08-15-2017)
Old 08-15-2017, 01:20 AM   #8
strat61caster
Are there setups that don't allow for free rotation of the Macpherson strut?
The OE top hat has a bearing, all included camber plates should have a spherical that allows it to rotate... maybe you mean if they're all gunked up and dirty?
ineedyourdiddly
Old 08-15-2017, 03:33 AM   #9
mav1178
mav1178's Avatar
Same thing with the usage of the term "coilovers", most places won't bother explaining to you that your stock suspension is already coilovers.
It's just something not high on the priority list, but you do have to check from time to time. Kinda like tire pressure, you assume the end user knows how to check...
The Following User Says Thank You to mav1178 For This Useful Post:
Old 08-15-2017, 05:09 AM   #10
churchx
churchx's Avatar
Drives: 2014 GT86
mav1178: depends on previous modding & sport history i guess. This car is first i actually mod and first i would consider sporty parts upgrades for due starting track use .. so it wasn't "as given"/self-obvious to me too, i'd more probably expect along the lines "if part X costs 4times the OEM costs, i'd expect everything in it better then OEM counterpart as given, or at very least on par, including expected longetivity or maintenance free". Hearing something like eg. that some rally coilovers get overhauled after 1K km surprised me a lot. So very probably that unlike tire pressure regular check up of aftermarket parts could have been missed by me aswell.
Old 08-15-2017, 09:26 AM   #11
jvincent
jvincent's Avatar
Given how hard I tightened the collar when I put the coilovers on I was definitely in the set and forget camp.
That's the annoying part. I have my wheels off all the time and just never thought to check this.
Live and learn.
Old 08-15-2017, 09:54 AM   #12
e1_griego
e1_griego's Avatar
Drives: Many
Most cheapy coilovers just have a camber plate bearing and a fixed upper perch. The bearing in the plate a lot of times doesn't want to turn axially so it starts to undo the collars with the turning of the wheel.
The Following 5 Users Say Thank You to e1_griego For This Useful Post:
mrjj (02-18-2022), RJasonKlein (08-15-2017), Scargod (02-15-2022), strat61caster (08-15-2017), Ultramaroon (08-15-2017)
Old 08-15-2017, 04:31 PM   #13
mav1178
mav1178's Avatar
Well, the vast majority of people modifying cars don't even bother to replace key nuts and bolts on the suspension when swapping out arms.
The reason why the manufacturer recommends you to change them is because they are designed to lock and last till at least the next service interval.
I can't think of a normal enthusiast that will change out their front strut bolts after swapping to coilovers, but that's precisely what is recommended when you change out your struts.
The Following 2 Users Say Thank You to mav1178 For This Useful Post:
Old 08-15-2017, 05:27 PM   #14
mav1178
mav1178's Avatar
Actually the true reason for coilover springs to move/loosen the perch is kind of why we have cheap(er) coilovers and economies of scale: standardized springs.
They basically took some standard spring size/dimension w/ a flat perch (Eibach ERS, Swift, H&R, any coilover spring with a standard inner diameter, free height, and rate), and added flat threaded perches on a threaded body so you can adjust height.
OEM struts have a stopper design built into the end of the last coil of the springs where it sits in the front/rear spring perch, so the spring can never physically move once it is properly installed. Aftermarket do not, so the springs can rotate when the suspension is unloaded. In the case of a Macpherson strut front design, the strut rotates with steering input so the tendency for the perch to loosen is higher.
Preloading the springs may reduce this but does not entirely prevent perches from loosening.
Coilovers Coilovers, Coilovers: Tein, KW, BC, D2, Cusco, Eibach + more FREE SHIPPING! No Limit Motorsport Brakes, Suspension, Chassis 204 05-26-2017 12:09 PM
Help! From check engine light to fouled plugs back to check engine + plugs refouling larchamb Issues | Warranty | Recalls / TSB 44 04-03-2016 09:39 AM
WTB: Ksport Control Pro Coilovers or BC Racing Extreme Low Coilovers ProjectBrz Brakes, Suspension, Chassis 1 04-15-2014 12:21 AM
* BC Racing BR Coilovers & Stance Super Sport Coilovers | IN STOCK | FAST SHIPPING * Speed Element Brakes, Suspension, Chassis 21 03-03-2014 08:56 PM
FS: (IL) KW Variant 3 coilovers and Stance Super Sport Coilovers ill roller Brakes, Suspension, Chassis 5 12-14-2013 03:02 PM
