Old 08-12-2017, 04:41 PM   #1
perryair
junior mafia
Drives: ‘20 sti limited
summer tires in the winter?
not to drive on, cause i know better than that but even to literally just be mounted on my car?
i live in nashville and wintertime isnt too severe but usually does come with a few days of 20 degrees or colder and cause i dont have a garage for either my brz or my dd, i'm hesitant to buy summers because i don't want the compounds to crack. anyone that's a tire guru have thoughts?
20 sti limited | 17 bmw m240i | 16 scion im |15 brz limited {prokit, 17x8 +35 rpf1, bfg comp 2 a/s, stg 2, jdl uel, voodoo knob} | 05 honda civic | 06 scion tc | 95 mustang gt | 89 chevy s-10 cameo
perryair is offline   Reply With Quote
Old 08-12-2017, 07:24 PM   #2
churchx
churchx's Avatar
Drives: 2014 GT86
If just some days in winter see -5C then average temps probably are by 10dg warmer .. my choice would be normal summers for well, summer, and all season tires for winter. From all seasons i've seen very often mentioned/positively spoken about michelin pilot sport A/S 3.
Old 08-12-2017, 07:30 PM   #3
If just parked the summers are fine. The cold only harms them if driven.
Old 08-12-2017, 10:08 PM   #4
perryair
junior mafia
but when you read the mfr notes it literally says that just being in 20 degrees or lower can cause damage to compounds. is that ignorable or real?
Old 08-12-2017, 10:21 PM   #5
If tires were damaged just by cold temperatures then all stored in unheated warehouses would be junk. Tire are pretty durable when not in use.
Old 08-13-2017, 08:59 AM   #6
wparsons
wparsons's Avatar
Not entirely true... most of the current EHP summer tires can actually have the rubber compound damaged if exposed to freezing temperatures. The sticker on my AD08R's specifically said not to store below 10* C.
That said, if it's not a super sticky ~200TW tire and just a normal summer tire then it'll probably be fine. I wouldn't personally let a Rival, RE71R, AD08R, R1R, RS4, etc sit out in freezing temperatures though.
flickr
The Following User Says Thank You to wparsons For This Useful Post:
ls1ac (08-15-2017)
Old 08-13-2017, 09:42 AM   #7
Fair enough. There are always exceptions. I was refering more to your "normal" summer passenger car type tires.
Old 08-13-2017, 10:53 AM   #8
Cole
Not a troll
Cole's Avatar
FWIW, my RE71Rs sat in the pool shed (not insulated) all winter. I inspected them in the spring when i put them on and no visible damage. Have been regularly checking the tires since then, and they still look fine.
Old 08-13-2017, 04:48 PM   #9
perryair
junior mafia
but they also werent supporting the weight of your car while at those temps. those of us in the south dont typically have sets of winters laying around nor sometimes places to even put them.
i'd like to think about getting a set of super sticky tires cause my brz is more of a weekend warrior, but the possibility of cracked tires because they were sitting through the random 10 degree winter day that we get sometimes down here makes me a bit apprehensive.
Old 08-14-2017, 08:52 AM   #10
wparsons
wparsons's Avatar
Look fine, and have the same grip, are two very different things. You won't see cracks, but if they were damaged by the cold they'll behave like they have been heat cycled out.
flickr
The Following 2 Users Say Thank You to wparsons For This Useful Post:
Cole (08-14-2017), ls1ac (08-15-2017)
Old 08-14-2017, 09:16 AM   #11
SuperTom
SuperTom's Avatar
Drives: C5, GT-86, '24 Colorado TrailBoss
Not true check with the manufacture recommendations a lot of summer tires will crack up even if just stored in subfreezing temps.
SuperTom is offline   Reply With Quote
Old 08-14-2017, 09:25 AM   #12
Meh. And most will not be harmed in the least. They are tires made out of synthetic compounds not delicate tropical plants. They receive more "damage" from 15 minutes of track use than from being in the cold. If stored cold though you need to let them warm up gradually and most certainly do not try to use them at those temperatures.
Sure, as said, some very expensive top of the line tire may suffer from extreme cold but the guys using those tires are not asking the question.
wparsons (08-14-2017)
Old 08-14-2017, 09:57 AM   #13
Cole
Not a troll
Cole's Avatar
Have noticed some drop off in the grip, but my grand hopes of being able to make it to autox crashed and burned for the second summer in a row. Ah well, maybe next year when I get another fresh set of them.
The Following User Says Thank You to Cole For This Useful Post:
Old 08-14-2017, 03:13 PM   #14
wparsons
wparsons's Avatar
Rule of thumb, if the tire can heat cycle out then I'd be worried about storing in freezing temps. If you don't know what that means, or the tires aren't a super sticky tire that'll heat cycle out then you'll be fine.
Even if they are damaged by the cold, they'll still be sticky... just not at the same level as before. It's not like they'll go from super sticky to being hockey pucks.
flickr
ls1ac (08-15-2017), Tcoat (08-14-2017)
BRZ Coilovers / Summer & Winter iSynck Canada Classifieds 5 03-22-2017 09:27 AM
Winter Tires worth it in Jersey for the remaining of this winter? Jfheisenberg Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 8 01-22-2015 10:58 AM
Some help please! Problem when swaping from summer to winter set! VirUzxZ Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 5 11-24-2013 03:15 AM
summer and winter tires s2kdrew Canada Classifieds 0 11-09-2013 09:53 AM
summer and winter tires s2kdrew Canada Classifieds 0 11-09-2013 08:17 AM
