Drives: GT86 2013
transmission leak
I spotted a bit of oil right where the driveshaft is attached to the transmission. It's a 2013 with 25k km on it.
Leak or normal? |
Oh, I don't really know. It could be a leaking rear transmission seal.
However, before you do any major surgery, I'd suggest you clean up the area real good and then drive it for a spell to see if the oil residue returns. humfrz |
| The Following User Says Thank You to humfrz For This Useful Post: | Drakiv (10-27-2017) |
Drives: GT86 2013
Checked again now, and there is a drop of fresh oil. It might have dripped, so its difficult to say how much it has actually leaked. There is no oil on the garage floor.
Is there an easy way of finding the oil level in the transmission? I'm doing an end-of-warranty check next year, it would be nice to postpone repairs until then, but obviously i don't want to break anything. |
not playing cards
That's just a tiny bit of weeping. Inconsequential. In comparison, mine leaked about 200 mL after installing the driveshaft with a little piece of sawdust in the seal. It made a huge mess burning all over the exhaust and coated everything all the way back past the differential.
Just keep a casual eye on it. You will know well before there is any real damage.
The Dictater
Drives: '13 Red Scion FRS
If you are still worried about it, you could always open the transmission fill plug and check. There's a diy on here that has pictures of where that is. Might need another crush washer though? Can't remember which one has a regular steel washer.
#6 | |
humfrz |
Drives: GT86 2013
Thx guys! Checking the auto oil is actually required for the 4.th years service. So i won't worry about it until then.
Drives: 2017 WRB M/T BRZ
Is yours an Automatic or Manual Transmission?
I Love custom Turbo kits
Drives: Limited BRZ
I've seen dozens of 86s and have never come up to find a leak in the area. I wouldn't be extremely concerned, but it's definitely something to take a look at and fix (probably the seal went bad).
| The Following User Says Thank You to Sportsguy83 For This Useful Post: | skogs (10-31-2017) |
| Transmission Oil Leak? | Euro7R | Issues | Warranty | Recalls / TSB | 11 | 12-13-2016 07:55 AM |
| Manual Transmission Leak | stock | Issues | Warranty | Recalls / TSB | 11 | 07-13-2016 10:15 AM |
| oil leak ! | frsqc | Issues | Warranty | Recalls / TSB | 5 | 07-01-2015 07:08 PM |
| A/T Pan leak | goke186 | Issues | Warranty | Recalls / TSB | 0 | 04-15-2013 10:31 PM |
| topspeed difference between manual transmission and automatic transmission | torquemada | BRZ First-Gen (2012+) — General Topics | 51 | 05-04-2012 07:54 PM |
