Old 08-06-2017, 11:58 PM   #1
SEITEN
Drives: SUBARU BRZ 2013
Hankook Ventus v12 Evo2 Tire Pressure
hi all,
currently i am running hankook ventus v12 evo2 tires (235/40R/18) on wedssport tc105n wheel (18x8), and the tire press was set ~34 psi but car tire pressure gage is showing low tire pressure.
was wondering anyone running a similar setup and or know what's the ideal tire pressure for this setup?
SEITEN is offline   Reply With Quote
Old 08-07-2017, 12:01 AM   #2
swarb
Tire pressure sensor light is on because one tire is lower than the others.
There is NO ideal pressure for every setup and driving condition. 30-36 is a good starting point for most cars.
Old 08-07-2017, 07:53 AM   #3
Teseo
Drives: frs
Did you swap tpms?
Old 08-07-2017, 11:13 AM   #4
SEITEN
i checked all tires, and they are all around 34-35 psi
Old 08-07-2017, 11:15 AM   #5
SEITEN
Originally Posted by Teseo View Post
Did you swap tpms?
no i did not, all i did is swap wheels and tires
Old 08-07-2017, 11:16 AM   #6
SEITEN
i saw some people running 36-38 psi on 18 inch wheels, not sure if that's better?
Old 08-07-2017, 11:18 AM   #7
Teseo
Drives: frs
Thats the problem mate, you need to swap old tpms from your stock wheels to the new one
The Following User Says Thank You to Teseo For This Useful Post:
G-Man (08-07-2017)
Old 08-07-2017, 03:08 PM   #8
trippinbillies40
trippinbillies40's Avatar
Drives: '22 WRB
Definitely the problem. Also to be noted if you DO end up putting TPMS on the Weds... You mentioned all tires were 34-35psi. Subaru TPMS is suuuper touchy, so set the pressures when they're cold and make sure they're ALL 34 or ALL 35. One tire being a pound off can light up the TPMS. Carries over from the AWD cars where that's a bigger deal because of tire diameter having an effect on center diffs.
trippinbillies40 is offline   Reply With Quote
Old 08-08-2017, 12:10 PM   #9
SEITEN
Do I need to get a new tpms for the weds? Cause it doesn't come with one.
Old 08-08-2017, 12:28 PM   #10
Teseo
Drives: frs
Swap the original tpms to weds
Hankook Ventus V12 evo2 255/35-18 (Set of 4) switchlanez Wheels and Tires 0 12-25-2016 10:18 PM
FS: Hankook ventus v12 evo2 225/45/17 tires sebastiansim NY / NJ / CT / PA 0 06-20-2016 08:08 PM
Sumitomo HTR Z III vs Hankook Ventus V12 evo2 Natheria Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 06-09-2015 05:31 PM
2 used Hankook ventus v12 evo & evo2 tires slyder Wheels and Tires 5 06-09-2015 05:16 AM
Recommend tire pressure for Ventus v12 evo2 vinh359 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 05-27-2015 09:03 AM
