Old 08-06-2017, 02:07 PM   #1
AfterFXNinja
Drives: Man
Send a message via ICQ to AfterFXNinja Send a message via AIM to AfterFXNinja Send a message via Yahoo to AfterFXNinja
How to use head unit/nav while moving? 2015 FR-S
So when you're moving the head unit doesnt allow you to use some of the features, ie entering navigation address etc. I can understand its a safety issue, but if you have a passenger to enter in the info for you itll be all good Does anyone know how to bypass the safety lock on the bespoke unit on the 15 FR-S?
Thanks
AfterFXNinja is offline   Reply With Quote
Old 08-07-2017, 09:46 AM   #2
Jakinit
Drives: 2017 CWP BRZ Limited (MT)
I don't know about that particular unit, but usually if you take the wire from the headunit that goes to the parking brake sensor you can ground it and bypass that.
Jakinit is offline   Reply With Quote
Old 08-08-2017, 03:55 PM   #3
wparsons
wparsons's Avatar
Depends on if it needs the e-brake on, or just to not detect the car is in motion. If it uses GPS speed, grounding the e-brake sensor won't help.
flickr
Old 08-14-2017, 02:44 PM   #4
AfterFXNinja
Drives: Man
I think its gps speed, because if im not moving and im just on regular brakes (leaving e brake off) im able to mess around on the nav.
FS: 2015 BRZ limited Head unit dar3d3vil Audio/Visual, Electronics, Infotainment, NAV 5 06-12-2017 11:25 AM
[sold] 2015 BRZ OEM Head Unit sodjer Audio/Visual, Electronics, Infotainment, NAV 0 08-09-2016 06:30 PM
Brz Head unit into 2015 Wrx iamdaspoon Electronics | Audio | NAV | Infotainment 3 09-05-2015 12:21 AM
FS: OEM frs 2015 head unit mynameis940 Audio/Visual, Electronics, Infotainment, NAV 17 12-04-2014 12:39 PM
2015 BRZ Head Unit Makattack BRZ First-Gen (2012+) — General Topics 18 09-21-2014 02:53 AM
