Old 08-04-2017, 09:53 PM   #1
Derek J
Derek J's Avatar
Drives: 2016 Scion FR-S Asphalt
Question Looking for advice on HID conversion kits
I am looking for information on converting the stock halogens to HID.
I would like to convert the DRL/High/Low beams and see a lot of different options.
Looking for advice on what's good and what to avoid.
Derek J is offline   Reply With Quote
Old 08-04-2017, 10:20 PM   #2
Prodigalson
ThisGuyLoves86's
Prodigalson's Avatar
Drives: 2013 Scion FRS
I went with CREE LED headlights. Very bright, even lighting and are 6000k. Unless you get a full retrofit, the HIDs will not provide proper illumination, whereas the focal distance of the LEDs is generally matched to halogen housings. Some are better than others (hotspots, dim areas, aiming, etc). As mentioned, I'm fully satisfied with my Hikari's especially considering the $70 price.
Prodigalson is offline   Reply With Quote
The Following User Says Thank You to Prodigalson For This Useful Post:
stevesnj (08-06-2017)
Old 08-05-2017, 12:29 AM   #3
humfrz
There ain't nutten wrong with the lights that came with your car ...... just leave-em alone .......
humfrz
D5teph (08-05-2017)
Old 08-05-2017, 01:56 AM   #4
D5teph
Automotive Enthusiast
D5teph's Avatar
Drives: Zenki 86
humfrz
Man....I'm feeling that way now humfrz. I may just leave the stock halogen bulbs on.
But anyways to the OP, I just received an HID kit from Diode Dynamics and after the install (1) side was not turning on. I then switched the ballast to the other side and still won't light up. I think my FR-S doesn't like me messing with the lighting. Last time I installed anything lighting related for example LED DRLs, it burnt out my headlight housing and I ended up replacing the whole left headlight. Just something to keep in mind bro...
D5teph is offline   Reply With Quote
The Following 2 Users Say Thank You to D5teph For This Useful Post:
humfrz (08-05-2017), Teseo (08-06-2017)
Old 08-06-2017, 12:40 AM   #5
stevesnj
stevesnj's Avatar
I went to LED's 2 years ago, very happy. I have an eye issues and they helped me a lot. Needed to re aim down but that was it. Matched with 6k switchback up front and signals in red at the back. No issues at all.
My 2016 Build thread
Old 08-06-2017, 02:13 PM   #6
Capt Spaulding
Persona Non Grata
Capt Spaulding's Avatar
Drives: '15 BRZ (WRB)
Unless you can ensure the beam pattern/cutoffs are perfect I wouldn’t. We have far too many lumen lusters down here who retrofit HIDs or LEDs into their factory reflectors and end up lighting up everything but the road. They delude themselves into thinking they can see better because their lights are blindingly bright, but are only making certain their fellow drivers can’t see a thing.
I don’t know if they’ll fit an FRS, but the factory BRZ HIDs work amazingly well. I keep mine dialed down a notch around town and on two lane roads and raise them on lightly traveled or 4 lane highways. You need to make sure to dim them for oncoming traffic. For my aging eyes the cutoffs are perfect and on hi, you can see the actual road surface (not just reflectors) from hill top to hill top across a good quarter to a third of a mile. I love them.
Slow is smooth, and smooth is fast
Capt Spaulding is offline   Reply With Quote
Old 08-06-2017, 02:33 PM   #7
NAEightySix
Drives: 2015 Scion FRS 6MT (Asphalt)
TRS' Morimoto Retro-Quick kit may be what you're looking for, it seems to be of great quality, although I can't speak from experience because I used the Monogram Headlights on my car.
HID's with a proper projector setup definitely made a HUGE difference as far as visibility.
NAEightySix is offline   Reply With Quote
Old 08-06-2017, 07:16 PM   #8
RallySport
Drives: FRS
For low beams, Decent quality plug-and-play hid will be an improvement in your stock projectors. They're not on a par with a full retrofit in terms of light spread, but all things being equal the Xenon puts out more lumens than halogens, no question. Just make sure you stick with a 4300 K bulb or close to it, and look up how to bend your squirrel Finders.
It doesn't seem like there's a great upgrade for the stock high beams, however if you go retrofit you can use bi-xenon projectors and retain your stock reflector high beams and have double output.
RallySport is offline   Reply With Quote
Old 08-06-2017, 10:09 PM   #9
Prodigalson
ThisGuyLoves86's
Interestingly, mine seem a bit lower than the halogens. Might try adjusting them up a bit.
stevesnj (08-07-2017)
╬╬ WILWOOD Big Brake Kits ╬╬ Free Shipping - Expert Advice - Photos and more... FT-86 SpeedFactory Brakes, Suspension, Chassis 186 04-25-2016 02:28 AM
Meng Motorsports V.2 HID Conversion Kits Mengsta Exterior Parts - Lighting 131 12-06-2013 02:59 AM
LED/HID conversion kits (interior/exterior), USA stock & warranty WTF Exterior Parts - Lighting 0 05-22-2013 11:18 PM
LED interior conversion kits (interior), USA stock & warranty WTF Interior Parts (Incl. Lighting) 0 05-22-2013 11:17 PM
