Old 07-19-2017, 11:55 AM   #1
jayhoang
jayhoang's Avatar
Drives: 2014 Scion FRS
Brembo OE 4 Piston Feedback?
Hey guys, noticed this on the FT86speedfactory site recently -
http://www.ft86speedfactory.com/brem...l#.WW9_3LZJlhE
Anyone have any feedback or opinions on this? It appears it's a full bolt on application for our cars from Brembo - likely a better option than the Cadillac ATS or STI Brembo option.
But I'd like to know if anyone has jumped on this yet? Seems like a fair price - obviously not comparable to the GT kit but still another option!
http://www.lifewithjson.com
Instagram: jayhoang
jayhoang is offline   Reply With Quote
Old 07-19-2017, 11:56 AM   #2
jayhoang
jayhoang's Avatar
Shit! Sorry - wrong sub-forum. Mods can you please move to Suspension/Brakes/Chassis?
Instagram: jayhoang
Old 07-19-2017, 01:36 PM   #3
laksman91
Drives: BRZ Sport-Tech, Evo X GSR, E92 M3
I just installed this on my car. It's not an OE caliper its actually a Brembo GT kit that happens to use the same rotor as the STI (unconfirmed re: rotor).
I took it out on track last weekend and they performed exceptionally well - no brake fade after 20min+ sessions. I highly recommend them.
I did need a 5mm spacer to clear my 18x9.5 +40 CE28RT though - should be fine with your TEs.
laksman91 is offline   Reply With Quote
The Following User Says Thank You to laksman91 For This Useful Post:
jayhoang (07-19-2017)
Old 07-19-2017, 03:03 PM   #4
DustinS
DustinS's Avatar
Drives: 2013 Ultramarine FR-S
Think it is somewhat similar if not the same thing as CSG sells.
http://counterspacegarage.com/produc...-red-gt86.html
DustinS is offline   Reply With Quote
The Following 2 Users Say Thank You to DustinS For This Useful Post:
jayhoang (07-19-2017), Kordless (07-27-2017)
Old 07-19-2017, 04:00 PM   #5
jayhoang
jayhoang's Avatar
Thanks my dude! That's good to hear!
What rotors? Just plain or did you have the option of slotted/drilled?
My TE's are the same specs are your CE's - assuming I may need a spacer as well?
Instagram: jayhoang
Old 07-19-2017, 04:33 PM   #6
laksman91
I went with the slotted. As far as I know blanks aren't available.
The spacers were only needed due to the spoke design of the CE. TEs are way more BBK friendly
Old 07-19-2017, 04:54 PM   #7
lazyluka
Drives: GT86
The choice should be obvious then.
Not only is the CSG kit cheaper, it comes with @CSG Mike's seal of approval.
lazyluka is offline   Reply With Quote
Old 07-19-2017, 07:14 PM   #8
Lust
Drives: 2017 Subaru BRZ
I'm also looking at these and the AP Racing Sprint BBK if anyone can chime in on the differences.
Lust is offline   Reply With Quote
Old 07-27-2017, 01:31 PM   #9
driggity
Drives: Silver Coupe with a Boxer
The Sprint kit uses smaller diameter rotors so it may fit under some wheels that the Brembo kit doesn't. The Endurance kit is more comparable to the Brembo in terms of diameter.
driggity is offline   Reply With Quote
The Following User Says Thank You to driggity For This Useful Post:
Lust (07-27-2017)
Old 07-27-2017, 04:48 PM   #10
Lust
I contacted CSG and we determined that the Brembo would be a better fit for me. They are heavier but they would be able to handle heat way way better.
Old 07-27-2017, 05:53 PM   #11
Kordless
Drives: '13 BRZ Limited
Purchase this kit from CSG.
The GT kit keeps the stock brake bias as much as possible with a BBK and factory rear brake system.
Also CSG is an overall great contributor to this community, support them if you can.
Kordless is offline   Reply With Quote
The Following 2 Users Say Thank You to Kordless For This Useful Post:
CSG David (08-03-2017), jayhoang (08-02-2017)
FS: Tein SRC, 4 Piston Brembo GT, Cusco LCA darthwong1138 Brakes, Suspension, Chassis 22 08-20-2017 03:00 PM
AP Racing Essex Kit/Brembo/BBK Piston Spreader Tool? Tenino Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 14 10-24-2016 01:37 PM
WTB: Stock Piston macaulay7 Canada Classifieds 2 04-09-2016 06:46 PM
BRZ Piston Pictures AVOturboworld Engine, Exhaust, Transmission 12 07-06-2012 06:16 PM
