Drives: '16 FR-S RS2 MT, '06 xA Polar MT
I was searching thru this wheel section, trying to find a staggered 17" wheel section ( I saw a couple of 18" staggered) .
Is anyone running staggered 17" wheels ? I was thinking of a 7.5 front, 8.5 rear . In who ever is running some kind of staggered 17" wheel set up, what width tires do you have them wrapped with ? Thanks in advance. still searching….
Math is like Love, simple idea at first that quickly gets complicated
Slow driver, fast biker.
Drives: '16 86, '00 Celica GTS, Sportbikes
I'm not sure there's any upside to a staggered 17 setup- those of us who do it on 18's are kind of stuck with it due to the factory specifications. Kills tire life.
Drives: dark grey metallic Toyota 86 MT
I have a set of 17’s with 245/40 on 8.5” wheels up front and 255/40 on 9” wheels
Tires are Dunlop and wheels are CE28 RT
Wes
I was talked out of it. Told there were only drawbacks and no benefits
Drives: 1980 corvette, 2014 Subaru BRZ
but why though?
Only happy when it rains.
Drives: series.blue
So true, the only reason to run staggered is for looks, so there is zero reason to run 17" staggered. It destroys handling.
Not a troll
Why do you want to do it? Do you love understeer? Do you have being able to rotate tires?
Did it because it’s my car, my money and my experience.
If you don’t want to do it then congratulations and enjoy rotating your tires.
#9 | |
/scion
Drives: '13 86 M/T
"Practice makes better. Only Senna is perfect." - CSG Mike
#10 |
Drives: 16 Silver BRZ, 04 Silver WRX wagon
#11 |
Huge E85 fan!
Drives: 2016 Scion FRS
Just to play devil's advocate- if you install a header and tune your car increasing power a significant amount (10% is not unheard of over stock on a NA setup) than you should think about having slightly wider rear tires.
#12 |
Drives: 2014 GT86
guybo: .. why not wider all-around in such case?
#13 |
Thanks for the responses. I'll do further research , but at this point I'm leaving it 17 x 7.5 on all four corners.
#14 | |
Hombre
Drives: 1994 Supra Turbo
I've always found when thinking about changing something rather major in the driveline, I need to find a good, substantiated reason to change what the manufacturer did originally. I can tell you from experience that having staggered F/R is a pain, but necessary sometimes (e.g., my Supra, which came that way!)
A Toyota Racecar A Toyota......................Because.
Anyway, should not palindrome be spelled palinilap? |
| Work Meister S1R 17" & 18" staggered | Manji | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 5 | 10-20-2015 09:08 PM |
| WTB: 19" staggered 8.5/9.5 rims | PBlack09 | Want-To-Buy Requests | 3 | 03-22-2015 11:53 PM |
| Anyone else try running "square" tires on "staggered" wheels? | hamlet | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 21 | 12-19-2012 12:59 PM |
| WheelDude.com | 17" & 18" DPT in stock and ready to ship - Staggered and Square | WheelDude.com | Wheels and Tires | 15 | 11-09-2012 12:12 PM |
