Drives: Car
Pull the endlink out and flip it around inside the LCA which should straighten it more vertical. Whether it's offset or there's a spacer or something, you should be able to shift the bottom part in the LCA so that it's located more ideally. Yeah the sway bar will be at an angle but that's better than metal on metal contact limiting your suspension travel.
| FS: Whiteline Rear Endlinks, | Asidrive | Brakes, Suspension, Chassis | 4 | 06-25-2017 01:45 PM |
| Wtb oem lca and rear endlinks | bjun | Want-To-Buy Requests | 4 | 02-14-2017 02:11 AM |
| WTB OEM Exhaust and rear endlinks | Blood | New England | 1 | 02-01-2017 06:38 PM |
| Safe to jack car from rear diff (while potentially touching the cover)? | bloomy116 | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 5 | 05-29-2014 11:18 PM |
