Old 07-06-2017, 08:30 PM   #1
reynierpm
Drives: Toyota 86 2017 Black
Does change the headers require tuning?
I have change my OEM catback for the Perrin 3.0. Now I want to move forward and install an UEL Tomei headers, my newbie question is: does change the headers require tuning my car? If so what should I buy besides the part to get it tune?
Thanks in advance
reynierpm is offline   Reply With Quote
Old 07-06-2017, 08:49 PM   #2
BFIFE22
BFIFE22's Avatar
Drives: 2013 GBS BRZ Limited
If you are planning on getting a catless header then yes you will need a tune. Your two main options to tune are going to be the OpenFlash Tablet and Ecutek. OFT has preloaded off-the-shelf tunes, and one specifically for running a UEL header. You just reflash the car with the tune and you are good to go. You can fine tune in RomRaider if you would like.
Ecutek will require the license and then you will need to find a tuner that is familiar with it. IMO if you are just running an exhaust and UEL header the OFT will be the more cost effective option.
If you run a catted header you don't necessarily need a tune. I ran mine for around 1000 miles and only had 1 CEL for about 10 minutes. But I ended up flashing it with the OFT using a modified stage 2 tune
APEXi / JDL / Perrin / Grimmspeed / Tein / Hotchkis / TRD / RAYS / Michelin / Raceseng / JPM Coachworks / SWEIDIT / Carsmo / TOM's / OFT / OEM Audio
BFIFE22 is offline   Reply With Quote
Old 07-06-2017, 09:52 PM   #3
Detroiter
Detroiter's Avatar
Drives: 2014 Scion FR-S Monogram
You do not need a tune with any header. Getting a CEL for cat efficiency will not do anything other than cause you to fail emissions. If you are in a state that does not check like me then you are fine. If they do check in your state then you're fine until they check it again.
Also I ran my Tomei UEL catless header with no tune for months and never got a single CEL. Maybe I got lucky Regardless you do not need a tune for any exhaust work on our cars, It will just give you more power out of it
Raven
OFT Stage 2 UEL E85 | Tomei UEL Headers | Catless FP | Greddy Revolution RS Catback | HKS Air Filter | Toyota Badge Swap
Detroiter is offline   Reply With Quote
Old 07-06-2017, 09:54 PM   #4
KnightRyderx2
Drives: 2014 FR-S
Are you "required" to get a tune? No. Is it highly suggested to the best performance out of it? Yes.
KnightRyderx2 is offline   Reply With Quote
Old 07-06-2017, 10:20 PM   #5
reynierpm
With performance you mean .... ? More HP? Something else?
I won't like to be throwing money mostly because I have a lot of plans for this car and I need to save but if tune up will help me to gain something and worth it then for sure I'll be acquiring what I need and hiring some one to know about this topic
Old 07-06-2017, 10:36 PM   #6
KnightRyderx2
Drives: 2014 FR-S
Yes, horsepower.
When you change out the header you flow exhaust gases faster, when designed right, that alone will create horsepower. Since you now are flowing exhaust faster the ecu will try to change a few things, timing and fuel is the most important. This will sometimes add more fuel and retard timing a little taking away a bit of the horsepower you gained, not all just some.
That is where the tuning comes in. You want to change the timing and fuel, among other things, to levels that will make even more power then just the headers alone will do. Most performance parts that you put on cars are like this. They add power on their own but with a tune you can get a a little more out of it.
Old 07-06-2017, 11:26 PM   #7
lazyluka
Drives: GT86
Do you like the way the car sounds now?
Yes, a header will give you more torque/power, but if you look thru the forums you can actually get fairly good gains with just a tune.
Now I am not saying that just a tune will give the same gains, but if you wanted to save some money or spread out your purchases then the way to go would be:
-Buy OFT and tune your car (as mentioned earlier, the tunes are free)
-When you are ready, buy the header and re-tune (again the tune can be downloaded for free).
If you have long-term plans for your car or planning to run forced induction (SC or Turbo), or perhaps purchasing an ACE header, then it may pay to get an EcuTek tune.
The EcuTek tunes are not free, but they can be of a higher level and there are more tuners that support EcuTek.
Both tuning options will probably give similar hp/torque results with most headers. However, even if both have similar peak figures, the driving feel of the tunes may differ as well.
One more thing in favour of OFT, you buy it, you tune, you decide to upgrade to EcuTek? No problem, you just re-flash your stock tune and sell the OFT (you could buy one used and save even more when you sell it?)
lazyluka is offline   Reply With Quote
Old 07-07-2017, 06:31 AM   #8
bfrank1972
Drives: 2013 FR-S Argento
Yes, you should plan on getting a tune. Spend the extra on an OFT, download the stage 2 UEL map and use that. Anytime you significantly change the efficiency of you motor (adding a good header) you should re-tune, or you're not going to realize the majority of the gains.
Sent from my SM-N920V using Tapatalk
bfrank1972 is offline   Reply With Quote
Old 07-07-2017, 01:17 PM   #9
lantsalot
Derp
lantsalot's Avatar
Given the fact that you want to keep the car around for a while, I would suggest tuning it (with a reputable tuner/ tuning solution) out of an abundance of caution to ensure reliability and longevity of the engine.
lantsalot is offline   Reply With Quote
change headers? pepe Engine, Exhaust, Transmission 7 01-25-2015 07:32 AM
Please Help! Anybody know if these G503's will require spacers? I NEED THEM. Cynic.TV Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 11 04-08-2014 01:18 PM
FA20Club tuning policy change Andy@FA20Club Software Tuning 49 12-10-2013 02:41 PM
Delicious Tuning - 200+ whp E85, Stock Headers, EcuTeK ProECU DeliciousTuning Software Tuning 19 12-07-2013 12:01 PM
