| Southern California SoCal |
Drives:
8/5/17 Balcony Sizzling Summer Drift - Hosted by Slide Factory
Register at www.slidefactory.org Facebook event: https://www.facebook.com/events/128321541091966/ The skid-pad is the perfect track for Beginners yet technical enough for Advance drifters. It's a great place to learn dynamic car control such as donuts, J-turns, figure 8's, and drifting in a safe environment. ![]()
| The Following User Says Thank You to bryanttttttta For This Useful Post: | Octoman (07-13-2017) |
Drives:
Pro tip: tape your ebrake button down so it doesn't lock when you use it to initiate a drift.
Drives:
Protip2: pump your rear tire pressure to 45-50psi to reduce the contact patch on the FRS/BRZ to make it easier to slide. Adjust the psi higher if you have trouble spinning out, and lower psi if you are spinning out too easily.
| Drift Clinic at Balcony WSIR 3/11/17 - Hosted by Slide Factory | bryanttttttta | Southern California | 3 | 03-14-2017 11:54 PM |
| Drift Clinic at Balcony WSIR 1/28/17 - Hosted by Slide Factory | bryanttttttta | Southern California | 4 | 01-31-2017 11:31 PM |
| Drift Clinic at Balcony WSIR 1/28/17 - Hosted by Slide Factory | bryanttttttta | Tracking / Autocross / HPDE / Drifting | 0 | 12-23-2016 05:45 PM |
| Balcony Night Drift Clinic - 7/2/16 Hosted by SLIDE FACTORY | bryanttttttta | Southern California | 9 | 06-27-2016 12:44 AM |
| SOLD OUT - Balcony Drift Clinic 4/17/16 - Hosted by Slide Factory | bryanttttttta | Southern California | 4 | 04-19-2016 01:11 AM |
