Old 07-04-2017, 03:22 AM   #1
kevinnnface
Drives: brz
2017 brz Fog light bulb change possible???
I want to change my OEM LED foglights to a yellow bulb but I'm not sure how to remove the OEM bulb. Would I need to buy a whole new casing?
kevinnnface is offline   Reply With Quote
Old 07-04-2017, 08:02 AM   #2
Ernest72
Drives: 16 Silver BRZ, 04 Silver WRX wagon
No, its easy. Lift front of car- use jack stands. remove plastic clips for plastic guards under the car. You will see back of casing. I forgot how it opens, but I googled it and it was easy. Maybe 30 min to do both. A little longer if you are not an experienced wrench. I went yellow LED as well - they look pretty good. Not as good as yellow film, but then the glass is yellow all the time.
My bad, totally missed 2017. Mine is a 2016. So much for reading.
Do the film, the yellow is the best. Only issue is its yellow all day as well. it looks best with black, it looks ok on my silver WRX.
Ernest72 is offline   Reply With Quote
Old 07-04-2017, 11:25 AM   #3
Pho20
Drives: 2013 Subaru BRZ
Can you post a link to the yellow leds?
Pho20 is offline   Reply With Quote
Old 07-05-2017, 05:47 PM   #4
kevinnnface
Drives: brz
Here's a picture of the back. I'm not sure what I should do and I also bought the LEDs (2504/PSX24W) from Allah lighting from Amazon.
https://www.amazon.com/dp/B011480LNM..._g4vxzb6W9269E
The Amazon LEDs don't even look like they fit, or maybe I would have to shave some of the clips off...
Old 07-05-2017, 06:58 PM   #5
norcalpb
norcalpb's Avatar
almost positive the leds are soldered in (see: permanent)
Old 07-05-2017, 07:42 PM   #6
Poodles
Drives: 2015 Series.Blue
2017's come with LED fog light assemblies. If you want yellow, use yellow film to get the look.
Old 07-06-2017, 05:18 AM   #7
Willie Swoopes
Junior Pizza Joe
Willie Swoopes's Avatar
Drives: 2017 BRZ Limited Manual WRB
Is it really easy to install the film?
I've got a WRB and I like the blue with yellow look.
Bill
Scooby-Doo: Scooby-Dooby-Doo!
Shaggy: And like, Shaggy too.
Willie Swoopes is offline   Reply With Quote
Old 07-06-2017, 09:56 AM   #8
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
Bill
Yes, it's really easy.
Also, there's no "bulbs". It's a single sealed unit.
Old 07-06-2017, 01:00 PM   #9
Poodles
Bill
Yep, easy, but you'll have to remove the units to do it properly. It's also not going to be really deep yellow/amber like if the LEDs themselves were emitting yellow.
I've grown tired of the film personally, but I keep it on because I like how it looks off and the film protects the fog lights.
How to change BRZ fog light bulb? chenshuo Cosmetic Modification (Interior/Exterior/Lighting) 19 05-30-2020 05:31 PM
D.I.Y. - BRZ courtesy door light bulb change joergasm DIY (Do-It-Yourself) Guides 24 09-13-2018 02:06 AM
Change HID bulb on BRZ iLaw Cosmetic Modification (Interior/Exterior/Lighting) 19 11-05-2015 08:58 PM
Bulb Change - DRL stopped working PNW FRS Issues | Warranty | Recalls / TSB 5 07-12-2015 11:54 PM
How many online forum members does it take to change a light bulb? Hoahao Off-Topic Lounge [WARNING: NO POLITICS] 37 02-27-2015 09:42 PM
