Northern California NorCal
Old 07-03-2017, 01:54 PM   #1
Derek J
Derek J's Avatar
Drives: 2016 Scion FR-S Asphalt
Replacing headers in NorCal?
So I've been looking and was thinking about replacing the stock header with this:
https://www.86speed.com/products/jdl...th-header.html
My question is, will me car not pass smog if I do?
Derek J is offline   Reply With Quote
Old 07-03-2017, 01:57 PM   #2
PMok
Codename: Stitch
PMok's Avatar
No it will not pass smog. Replacing the OEM header with anything else will not pass.
Old 07-03-2017, 02:00 PM   #3
Derek J
Derek J's Avatar
How difficult would it be to swap them?
My car is relatively new, 2016 with 17k miles.
Old 07-03-2017, 02:02 PM   #4
Exrald
Exrald's Avatar
Drives: 2013 Scion FRS & 2022 GR86
Yeah, that's the drawback for me too. I'm planning to get Tomei uncatted instead. We have two cats, so you don't have to worry about the smell. Once you do the Smog Check, just slap back the OEM on. It's a hassle, but you only gotta do it once every 2 years.
2013 Scion FRS @Exrald.frs
2013 Scion FRS
2022 Toyota GR86
Exrald is offline   Reply With Quote
Old 07-03-2017, 02:06 PM   #5
Derek J
Derek J's Avatar
How about this exhaust?
http://perrinperformance.com/i-22819...-s-brz-86.html
Is that going to cause me problems?
Old 07-03-2017, 02:13 PM   #6
Exrald
Exrald's Avatar
It shouldn't. It's a Catback. I got ARK Grip Catback. Yours is resonated too, so yours isn't that loud.
2013 Scion FRS
2022 Toyota GR86
Old 07-03-2017, 03:07 PM   #7
PMok
Codename: Stitch
PMok's Avatar
It's not particularly hard but you will have to get under your car. It will help a lot if you have a lift. If you're lazy like me you can get a shop like Elite Performance or The Racer's Line or Mann Engineering to do it for you.
You actually get 6 years the first time after purchase of the car new. So for a 2013 you have 2 more years to go, for a 2016 you have 5 more years before a smog is required.
Old 07-03-2017, 06:49 PM   #8
Exrald
Exrald's Avatar
Just to make sure tho. Since we have two cats, there wouldn't be an obvious smell if I change my headers right? Like it would pass the Smell test?
I was told by my friends that it should be fine, but some said it might be worrisome...
2013 Scion FRS
2022 Toyota GR86
Old 07-03-2017, 10:03 PM   #9
dchan
Drives: DGM BRZ
I have a catless header, and the car smells funny on start up. It goes away once the second cat warms up though.
dchan is offline   Reply With Quote
Old 07-03-2017, 10:06 PM   #10
Exrald
Exrald's Avatar
How about on Idle?
2013 Scion FRS
2022 Toyota GR86
Old 07-04-2017, 02:39 AM   #11
dchan
Drives: DGM BRZ
How about on Idle?
The only time I smell anything is before I pull out of my garage after being parked all night.
Old 07-04-2017, 02:54 AM   #12
PMok
Codename: Stitch
PMok's Avatar
it doesn't matter since for 2000+ model years there is no sniffer test. The CA smog inspection for newer cars has two components. (1) the computer OBD2 check and (2) the visual inspection. The reason why you fail with a header is the visual inspection. Any reasonably alert smog tech will be able to tell that your header is not OEM.
Old 07-07-2017, 08:22 PM   #13
Pish
#teamswagoi
Pish's Avatar
Drives: 2014 Raven FR-S Monogram
This.
Pish is offline   Reply With Quote
Old 07-11-2017, 09:01 PM   #14
Mchilese
Mchilese's Avatar
Drives: '14 BRZ Limited
Being from AZ, I just can't stand CARB. What does a "visual" inspection tell anyone other than you don't have OEM parts? It should depend on a sniffer and/or the OBDII test, at most. If the sniffer doesn't go off, and the computer doesn't show anything weird, what's the difference?
2014 BRZ
Mishimoto intake tube/TSW Nurburgring 18x8/Firestone Firehawk Indy500s/PLM muffler delete/JDL catted UEL headers
Mchilese is offline   Reply With Quote
wtb: Catted Headers (Norcal) bkblitzed Engine, Exhaust, Bolt-Ons 0 06-01-2014 10:24 PM
Replacing the BRZ mustache FrSnake Cosmetic Modification (Interior/Exterior/Lighting) 5 05-06-2014 01:15 AM
Replacing headers only diss7 Engine, Exhaust, Transmission 36 11-17-2013 12:28 AM
anyone have DIY for replacing OEM HU?? mbh1101 DIY (Do-It-Yourself) Guides 2 01-27-2013 12:18 PM
