Old 07-03-2017, 12:12 AM   #1
mrhandle
Drives: Genesis Coupe 2010
Very noobish question
Please excuse my question beforehand because I'm new to the game and does not have clue what is what so please be aware with me. Speaking of which, I'm planning to buy http://www.ft86speedfactory.com/ft-8...l#.WVnC6ojyvIU inspired by other user in this forum. And my question is that can I only switch out it's muffler and use my stock front pipe instead of front pipe it comes with? (only because I don't want my exhaust to be too loud and it seems using stock front pipe would reduces its loudness) if I can, are there any separate materials that I need to buy in order to connect its muffler and stock front pipe or I'm good to go without any? Thank you very much!
mrhandle is offline   Reply With Quote
Old 07-03-2017, 01:04 AM   #2
Overdrive
Sittin' Sideways
Overdrive's Avatar
Drives: 2016 Toyota FR-S
Don't sweat asking a noob question, but try using the search function in the future, because your answer is very likely somewhere in this forum from plenty of other people asking the same question in the past.
Unless I'm missing something, I don't see anything about a front pipe as a part of this package. It's just the midpipe and axleback sections (a typical catback setup), so you'd still be using your original front pipe because you're not eliminating any catalytic converters (one exists in your header, the other in your front pipe). From the videos they posted on that product page of just this bolted on to the car it's really not that loud even when you get into the happy section up high.
Have a look at this vid, and keep in mind that they're installing a catless header on top of that catback, but they are using the stock section between the header and the midpipe (which would be your front pipe):
[ame="https://www.youtube.com/watch?v=iM_QmVF2-fQ"]Searching for Torque - Header & Exhaust - FR-S Long Term #4 - Everyday Driver - YouTube[/ame]
So just keep in mind that this car in the video is much louder than what you'll end up with due to having the aftermarket header along with the exhaust, and even then it's not ridiculously loud. Your car won't be loud at all with the catback alone.
Also helpful is the attached diagram below. You're only changing the two pieces on the right of the image:
-O/D
2016 FR-S, Hot Lava
Overdrive is offline   Reply With Quote
Old 07-03-2017, 01:24 AM   #3
humfrz
Yep, ol @Overdrive fixed you up good there ......
humfrz
Turn Signal Relay Question (Dumb Question) Chimera Cosmetic Modification (Interior/Exterior/Lighting) 3 06-23-2017 01:58 AM
A few noobish questions bdanisi Off-Topic Lounge [WARNING: NO POLITICS] 8 04-16-2014 05:46 PM
Noobish exhaust/CAI question NorseLegend Engine, Exhaust, Transmission 20 03-06-2013 11:56 PM
BEspoke question and rattle question bdanisi Electronics | Audio | NAV | Infotainment 2 01-30-2013 02:11 PM
'Noobish' questions as I look to upgrade my car audio audio. DkY in Vcr Electronics | Audio | NAV | Infotainment 0 09-22-2012 09:45 PM
