Old 06-29-2017, 11:32 PM   #1
nickjpass
nickjpass's Avatar
Drives: 2013 Firestorm FR-S
Condensation in tailights.
I have none. 35k miles, 2013 frs. The thread is too long to search through in the recall section. Should i do anything to prevent it? Or just leave it alone?
nickjpass is offline   Reply With Quote
Old 06-29-2017, 11:33 PM   #2
If you don't have it now you probably won't. Just leave well enough alone and don't do a thing.
Old 06-30-2017, 02:42 AM   #3
Twitchy313
Twitchy313's Avatar
Drives: 2014 Scion FR-S
Which tail lights do you have?
Twitchy313 is offline   Reply With Quote
Old 06-30-2017, 08:33 AM   #4
alan.chalkley
Drives: 4wd zooks
The tail light condensation problem was with the initial 2012 production.
alan.chalkley is offline   Reply With Quote
Old 06-30-2017, 08:35 AM   #5
MurderousPandas
MurderousPandas's Avatar
Drives: 2013 Scion FRS
I live in south Florida with a '13. Slight condensation, but nothing bad. You can try to add sealant around the border to prevent it, but you've already made it this far. And it gives a good reason to upgrade to Valenti if it does go bad.
Sent from my HTC6535LVW using Tapatalk
MurderousPandas is offline   Reply With Quote
Old 06-30-2017, 09:46 AM   #6
Scrappydoo
Scrappydoo's Avatar
Drives: Grrrr
I don't have any punctures at the moment.
What should I do about it?
Scrappydoo is offline   Reply With Quote
Old 06-30-2017, 11:03 AM   #7
Silver Cervy
*Some really cool title*
Silver Cervy's Avatar
Normally I'd ignore what Scrappy says, but this time he has a point. Not worth it worrying about a problem that isn't there, and even if it does appear is very easy to fix.
If it's bothering you that much, then the two easiest solutions are drilling a hole in the bottom corner of the housing to allow the water to vent out, or sealing the border between the tail light and trunk vent with silicone (which is what I did).
Silver Cervy is offline   Reply With Quote
Old 06-30-2017, 08:21 PM   #8
humfrz
...... the answer is obvious, buy run flat tires ......
humfrz
Scrappydoo (06-30-2017)
Old 07-01-2017, 09:12 AM   #9
nickjpass
nickjpass's Avatar
Thanks guys. I figured I shouldn't do anything, but the thread was so long that I wasn't entirely sure what the issue was. Thanks for the reassurance guys.
Next up: My car seems to be running perfectly, does that mean the exhaust bearings need to be replaced? Stay tuned.
Old 07-01-2017, 04:14 PM   #10
humfrz
Nah, they are sealed bearings and are good for 100,000 miles or 10 years, whichever comes first.
You're a good sport there, nickjpass ...... we'll let you hang out here .....
humfrz
nickjpass (07-04-2017)
FS: OEM tailights VirginiaBRZ Exterior Parts (Aero, Lighting, Etc.) 5 03-23-2016 11:21 AM
Tom's tailights halo13 Cosmetic Modification (Interior/Exterior/Lighting) 16 01-29-2016 03:49 PM
FS: OEM Tailights BRZ/FRS TONYpepperon1 Exterior Parts (Aero, Lighting, Etc.) 12 05-22-2015 05:34 PM
Some tailights we might have to get used to seeing! NOHOME Other Vehicles & General Automotive Discussions 48 12-25-2014 01:02 AM
Where can i buy these tailights!! Amir_joon Cosmetic Modification (Interior/Exterior/Lighting) 6 07-01-2014 11:19 AM
