Old 06-29-2017, 08:06 AM   #1
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
Washer fluid fill
My washer fluid reservoir was empty for about 6 months, so I finally filled it and now my car over steers like crazy.
Did I throw off the weight balance from front to rear and have too much tread on my front tires from the lack of weight? Will rotating my tires fix this?
Old 06-29-2017, 08:45 AM   #2
You need to install the springs from the 17s in the rear and replace the air in your spare with helium to counter this.
Oh and don't forget to cut your bump stops off.
Old 06-29-2017, 09:29 AM   #3
Dawan
Le Ingenieur
Dawan's Avatar
Drives: 2015 Subaru BRZ Aozora
You guys are ****s LOL
Dawan is offline   Reply With Quote
Old 06-29-2017, 09:32 AM   #4
Andrew025
Andrew025's Avatar
But I already have a 2017?!
I hate this forum. Just full of trolls and you're killing the community. That's why no one is on this forum anymore.
Old 06-29-2017, 09:35 AM   #5
yelsew
Little Member
yelsew's Avatar
Drives: Bloo - The 13' BRZ
It doesn't matter anyways, These cars are absolutely terrible at everything they do, and you'd be an idiot to buy one. Better buy a superior GTi or something else before your resale value plummets any further...
<--- My Journal
People just need some #drivermod in their life.
yelsew is offline   Reply With Quote
Old 06-29-2017, 09:41 AM   #6
How on earth did you manage to buy a new one without 28.6 threads asking which one you should get?
See the problem is they used a cut down Impreza platform so you need the springs from a 13 on the front to get it right.
Also need the struts from a 14 on the left and a 16 on the right. All this will work very well with the Torsen LSD. This is important if you don't want to wear your tires out after 3 powerslides.
Old 06-29-2017, 09:42 AM   #7
But that seat pattern on the GTi is a deal breaker.
Old 06-29-2017, 09:45 AM   #8
yelsew
Little Member
yelsew's Avatar
Yeah, but I bet Volkswagen covers track use in their warranty. Only Subaru and Toyota don't because they hate us so much.
<--- My Journal
Old 06-29-2017, 09:48 AM   #9
Well a $25K sports car really should be able to take the pressures of track use without issues. I mean really, I had to save up for 5 years for the down payment.
Old 06-29-2017, 09:51 AM   #10
Andrew025
Andrew025's Avatar
I've been too busy trying to get ready for prom to make threads about it.
Do I need to remove my sway bar as well?
Old 06-29-2017, 09:51 AM   #11
StraightOuttaCanadaEh
Wes
Can a full washer fluid reservoir really cause oversteer? First that battery thread, now this. Am I just not as in tune with the car as the rest of youse? What's the capacity of the reservoir anyway? Or is this a troll thread and I'm stupid lol
Old 06-29-2017, 09:51 AM   #12
Satire.
Old 06-29-2017, 09:52 AM   #13
Andrew025
Andrew025's Avatar
It's gotta be at least 10lbs of fluid at the very front of the car.
You obviously need to drive your car more if you can't feel it.
Old 06-29-2017, 09:52 AM   #14
Wes
Satire.
okay phew
Washer fluid not spraying out btan219 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 37 09-16-2019 05:35 PM
Washer fluid tank, need to fix asap. SavingManuals Electronics | Audio | NAV | Infotainment 0 11-22-2015 06:12 PM
Window washer fluid light? husker741 Scion FR-S / Toyota 86 GT86 General Forum 14 10-20-2013 12:15 PM
Washer Fluid Indicator Tdot BRZ First-Gen (2012+) — General Topics 58 02-19-2013 04:02 PM
FYI - Washer Fluid light Ben_G BRZ First-Gen (2012+) — General Topics 48 01-03-2013 04:18 PM
