Old 06-26-2017, 07:52 AM   #1
ogrowup
Drives: Asphalt build in progress
E85,pump gas,NJ turnpike,P011 code
I've got a brain buster here. Twice in the past 2 months I drove to NY from Maryland. Both times I started with a full tank of E85, and at 1/2 tank topped it of with 93 pump gas. When I refilled the tank I was now on 100% 93 pump gas.
Both times the ck engine and DSC light came on. I carry a scanner and both times is showed a P011 code, and I cleared the codes. Car ran fine both times but the code had to be cleared. The second trip the ck engine light and the DSC light came on a second time and I just kept driving.
The next day when I started the car both lights were still on. I filled the tank with E85, and the lights went off. I am now running 93 pump only to see if I can recreate. The lights have NOT come back on.
Anyone have any idea what's happening? Anyone ever get a P011 code?
My car is boosted and the tune was done by a top line company. Curious if anyone has some wisdom to share on this.
ogrowup is offline   Reply With Quote
Old 06-26-2017, 10:34 AM   #2
steve99
You talking P0011 cam position code ??
also is this trip the only time you go off full E85 ??
check out TSB
http://www.ft86club.com/forums/attac...0&d=1352490977
unfortunatly its one of the more difficult issues to fix
Old 06-27-2017, 03:09 PM   #3
ogrowup
Yep P011 cam position
I've gone off E85 before and I've been driving for two weeks on 93 only. Ck engine and disc lights have not come back
E85, pump gas, New Jersey Turnpike and P011 code ogrowup Issues | Warranty | Recalls / TSB 1 06-26-2017 01:06 AM
p0462 fuel level sensor code. anyone else ran into this code georgiafrsguy Engine, Exhaust, Transmission 1 02-28-2017 08:28 PM
Toll/Turnpike Sticker Problems meow_mix Electronics | Audio | NAV | Infotainment 6 05-06-2015 08:42 PM
Asphalt FRS on Turnpike North this AM Trmx2 Southeast 0 11-25-2013 09:27 AM
Orlando Turnpike e85? Yeah, no--more like e75... GTB/ZR-1 Southeast 4 06-03-2013 09:31 AM
