Old 06-23-2017, 08:35 PM   #1
Eazy-V
Any 3" Over pipes with no fitment issues
Does anyone know which over pipes are 3" with no fitment issues?
I already have FBM turbo with 3" down pipe and JDL 3" catted front pipe, so I need a 3" over pipe.
FBM Base Turbo Kit with GTX2867R and FlexFuel Kit with Walbro 485 / 550cc Injectors
EcuTek Tuned witih Greddy Profec @ 12PSI Shell 91-E73 and 18PSI E73
1993 Mazda MX6 N/A Fully Built on MegaSquirt (work in progress)
2023 Chevrolet Corvette Z51 Stock
Last edited by Eazy-V; 06-23-2017 at 08:37 PM. Reason: Pressed Go on brower on mistake
Eazy-V is offline   Reply With Quote
Old 06-23-2017, 08:52 PM   #2
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
The "without fitment issue" part would vary greatly on whether your engine mounts are good or not.
Old 06-23-2017, 09:11 PM   #3
Eazy-V
I have OEM engine mounts and sway bar, car only has 10000km
Old 06-23-2017, 09:15 PM   #4
mav1178
mav1178's Avatar
Based on my experience, mileage is not a good indicator of engine mount condition.
It's a combination of how the car is driven, the condition of the rubber, miles driven with harsh torque scenarios (launching the car, hard shifts, sudden drivetrain shock, etc), among others... even lowering the car and driving it over many harsh bumps would cause the mounts to fail prematurely over time.
Doesn't take much for your OP to hit if the mounts move even a bit excessively.
The Following User Says Thank You to mav1178 For This Useful Post:
Teseo (06-23-2017)
Old 06-23-2017, 10:06 PM   #5
Eazy-V
So, are you saying it I get stiffer aftermarket mounts that will help with fitment? Do you know which 3" OP fit? A lot of them are OP/front pipe combo or are designed for that manufacture's turbo kit.
Old 06-23-2017, 11:17 PM   #6
cjd
cjd's Avatar
Drives: 2017 BRZ
My 3" JDL over-front pipe fits perfectly... Not quite what you wanted but...
Old 06-24-2017, 12:24 AM   #7
Eazy-V
Actually that's exactly what I wanted, except are you running the v-band overpipe front pipe combo? What frontpipe are you running? I have the JDL 3" frontpipe flat flange and didn't realize until after there's a different JDL v-band combo setup.
Old 06-24-2017, 07:35 AM   #8
cjd
cjd's Avatar
Drives: 2017 BRZ
Yes, the v-band combo ultra-quiet over-frontpipe.
The Following User Says Thank You to cjd For This Useful Post:
Drakiv (06-24-2017)
Old 06-24-2017, 04:35 PM   #9
Eazy-V
Ok, yeah there doesn't seems to be a modular flat flange 3" over pipe that has no fitment issues, unless someone knows of one?
