Old 06-20-2017, 07:53 PM   #1
PresiO.
Drives: 2013 Scion Fr-s
Torque solution motor mounts
Hey guys,
Just wondering if anybody has tried the torque solution engine mounts? Ive been in-between the torque solution and the Perrin. I think the Perrin are a bit over priced since they give you the capability to pull the engine easier... which I probably won't do in a long long time so I don't feel the need for that. Which concludes why I don't care to pay the extra $100 or something dollars.
Thanks for any input anyone has.
PresiO. is offline   Reply With Quote
Old 06-21-2017, 12:57 AM   #2
Hawk77FT
Drives: GTS 86
Originally Posted by PresiO. View Post
Hey guys,
They will be hard af! You want to have some flex and shock absorption. I would look at the STI ones or something made of Poly. It also depends on the type of Aluminum they use to make them. For instance pressed aluminum allows the motors vibrations to be dampened a bit but it is really up to yo.
Hawk77FT is offline   Reply With Quote
The Following User Says Thank You to Hawk77FT For This Useful Post:
PresiO. (06-21-2017)
Old 06-21-2017, 02:16 AM   #3
humfrz
Does the FA20 engine have a torqueing problem ... ??
humfrz
Old 06-21-2017, 02:46 AM   #4
PresiO.
humfrz
No it doesn't. I just want to get them because I recently got some solid transmission mounts and don't want the engine moving a bit while the transmission has little to no play. Im sure it won't be good to throw on the solid mounts without strengthened motor mounts.
The Following User Says Thank You to PresiO. For This Useful Post:
humfrz (06-21-2017)
Old 06-21-2017, 08:55 AM   #5
cjd
cjd's Avatar
Drives: 2017 BRZ
humfrz
It theoretically reduces lag from input to time it hits the ground, but the throttle response is likely to remain a little laggy. It helped me with exhaust rattle against the frame under torque as well, which is why I got STI mounts in the first place.
The Following User Says Thank You to cjd For This Useful Post:
humfrz (06-21-2017)
Old 06-21-2017, 10:27 AM   #6
fika84
fika84's Avatar
humfrz
Depends on what you call a "problem"..
My reasoning for stiffening up the driveline was so that I didn't waste the little bit of torque it DOES have twisting equipment. Get that power to the ground baby!! I also hated seeing my shifter move when going from hard acceleration to hard deceleration and vise-a-versa.
It's different for everyone though, for me, I'm OK with the added NVH and I do occasional track days. I'm running Cusco mounts for what it's worth on this thread.
fika84 is offline   Reply With Quote
The Following User Says Thank You to fika84 For This Useful Post:
humfrz (06-21-2017)
Old 06-21-2017, 08:06 PM   #7
PresiO.
Do you like the cusco mounts? I heard those are the worst when it comes to NVH.
Old 06-21-2017, 08:07 PM   #8
PresiO.
How do you like your sti mounts? Is there a significant difference from stock?
Old 06-21-2017, 10:32 PM   #9
cjd
cjd's Avatar
Drives: 2017 BRZ
There likely is a difference because no more exhaust rattle. It's really tough to compare otherwise, but NVH is still good, and it was obvious with I think Cusco, more V... All things considered, pretty happy. Also they have the heat shield still, which can matter.
C
PresiO. (06-22-2017)
Old 06-21-2017, 11:51 PM   #10
ApexEight
Drives: 2014 Subaru BRZ Limited 6MT SSM
I believe the Torque Solutions mounts utilize poly, what's around the mount is what's made of aluminum. Will definitely increase NVH though. If the car is seeing more than 50% daily use I would imagine the STi mounts would be the route to take. I've read they make a noticeable and worthwhile difference.
ApexEight is offline   Reply With Quote
Old 06-22-2017, 01:34 AM   #11
PresiO.
Yeah, honestly thats probably the mounts that I will be going with.
Old 06-22-2017, 12:03 PM   #12
fika84
fika84's Avatar
They serve their purpose, which is remove flex under torque and get the power to the ground.
You don't put stiffer motor mounts on without knowing that your NVH is going to increase. If you want it to feel cushy and quiet, keep the stock ones.
FS: Perrin 3" Intake, Torque Solution engine mounts jonesy Engine, Exhaust, Bolt-Ons 4 01-10-2017 04:03 PM
Window weld motor mounts (poor man's solid mounts) unsurety Engine, Exhaust, Transmission 8 06-05-2014 02:36 AM
Torque specs for trans and motor mounts jah29 Engine, Exhaust, Transmission 0 06-27-2013 09:53 PM
