Drives: Not owned yet
Will these wheels fit?
Hello, I plan on getting 17x9 RPF1s with 255/40/17 tires. Will I need to roll my fenders or get coilovers?
Wheels for Brains
Potentially coil-overs, or at least spacers in the front.
I hear 245/40 tires cut it close. The tires might be too wide and rub on the stock strut in the front. Coil-over struts are often narrower, so you don't run into this problem. I am not speaking from experience, so potentially someone else with this actual set-up can give you a more direct answer. |
Read these:
http://www.ft86club.com/forums/showthread.php?t=15160 http://www.ft86club.com/forums/showthread.php?t=32719 tl;dr some people have run +35 on OE without much issue (might be too close for comfort for some), +45 will rub OE diameter springs/struts (or be too close for comfort at least, coilovers fix this) as well as the fender liner at full lock, the +45 issues can be fixed with a spacer if you have the length on the studs. |
Thanks, I'm looking to get the +45 so I'll read up on that.
Purist
Drives: 2013 FRS - Hot Lava
I have TR Motorsport 17x9 +45 and 245/40 tires. I need a 3mm spacer up front and they clear enough to never rub. 245 is plenty of tire.
| *Wheels Collection* Winter Package 2015-2016 (Alloy Wheels + Tires) | wheelsco | Canada Classifieds | 4 | 10-08-2015 03:55 PM |
| TWS Forged Wheels T66-F - Ultra lightweight Race Wheels with Style // DSG Performance | Jason@DSG | Wheels and Tires | 37 | 12-17-2014 02:50 PM |
| Discount Tire installed my wheels and tires...and damaged my wheels...advice needed! | stratodyne | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 16 | 07-17-2013 02:21 PM |
| Wheels, Wheels, Wheels | Island Import Performance | IslandImportPerformance | Wheels and Tires | 4 | 07-31-2012 10:08 PM |
