| Engine Swaps Discussion of engine swaps. |
Drives: 14 frs
Ls swap kit options
I have searched several post and most appear to be a little older. Is there a newer swap kit that has the electronic support. I want a/c and as many functions that I can get. I have the car and the engine ready to go. I have been speaking with wpg and vorshlag. 7500 seems to be a little stiff and the motec is six k just for electronics This will be my third ls swap and my first frs. Any ideas would be greatly appreciated..
Drives: 2015 frs
@MRS-Colin can hook you up with the can- bus solution if you don't want to go full standalone system. "Another V8 Swap" thread is pretty current. Your options for mounts are Vorshlag, CX Racing, Weapons Grade, or build your own. I went Vorshlag everything but the headers so far. I kind of wish I would have built the mounts myself to save some cash and get some Fab time in. I have spent to much now to backpedal. So far I am happy with the quality we will see once I start bolting things in if I like the fit and finish. Search a little deeper it's all on here.
Drives: 2015 Raven FRS
Check out Element Tuning. Phil has just about everything you need.
http://www.monster86.com/ Last edited by Lunatic; 06-17-2017 at 11:29 AM. |
Drives: 2015 Subaru BRZ
Drives: 2015 frs
Nice. I like that mount @wrxdriver2002.
Drives: 14 frs
Thanks for the help!
#7 | |
We are going to be working on the rear suspension here next as soon as my schedule and availability lines up with his. The brz rear suspension is super weak and I’ve seen some catastrophic failures from tiny incidents with curbs. |
When will these be released?
#10 |
Where is the placement of the engine? does the sway bar bolt up? does the engine clear the heater hoses? Does it clear the clutch master? Trans?
#11 | |
http://www.ft86club.com/forums/showp...&postcount=650 |
#12 |
Doesn't look like it supports the sway bar.
#13 |
It doesn’t, yet. We are working on making a sway bar work. Intimately it will probably be a custom bar because of the long tube headers my car has. Good thing is it will fit pretty much any condiguration anyone has in the future.
| Pentosin Trans Fluid Swap | Motul 300 Diff Swap | Impressions | Dezoris | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 15 | 06-06-2017 10:54 PM |
| Scion FR-S options:what options did you have dealer installed? | Scionshaun | Scion FR-S / Toyota 86 GT86 General Forum | 42 | 01-06-2014 01:35 AM |
| Bushing upgrades, geometry options and other component options? | der_rainman | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 10 | 06-26-2013 12:53 PM |
| BRZ/FRS Trunk Swap - Re-Badge Options? | KGFRS86 | Cosmetic Modification (Interior/Exterior/Lighting) | 8 | 06-21-2013 02:19 AM |
| Gearing Options and Diff options | airboy808 | Engine, Exhaust, Transmission | 26 | 12-25-2011 01:11 PM |
